Question about Sony PlayStation Portable (PSP) Console
Screen black i can play any games, but the problem, there is no clear resolotion or the screen is very dark even i adjust the brightness it is not working.
    Problem Solver:
  • 3 Answers
Ok did you try Pressing the button on the bottom of the psp to see if it made brighter if not try that. If that's not is contact sony.
Posted on Jun 23, 2008
MY IPHONE HAS A PLOBEM MY SCREEN IS VERY DARK EVEN I ENCREASE THE BRIGHTNESS IT STILL VERY DARK ???
Your display is going out sorry.If the back light is not making it brighter the screen is failing.
Apr 07, 2012 | Apple iPhone 3GS Black (16 GB)
Hi, we have a ps3 we play Black Ops on. Its connected to a Sony Trinitron tv w/composite cables. Lately, the picture has been very hazy and dark, no bright colors like it used to be. Its hard to see where...
green sounds like a TV problem if persists with other games could be TV but im kinda thinking it is ingame settings occasionally updates can reset picture settings in the game i think for black ops it had some kind of adjust brightness until you can't see this object in background and sometimes it helps to go back and check that only other explanation would be you went to different resolution ex: 480, 720(hi def), 1080(highest high def)
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Picture too dark
Hi kseguin
Your TV has internal problem @ video stage on the circuit
But you may try to apply resoldering on the circuit board near flyback and CRT circuit board.
Apr 14, 2009 | Panasonic CT-34WX52 34" TV
Laptop screen is very dark even though harddrive is running fine
There are several reasons this could be happening but lets try adjusting your brightness/contrast settings.
Go to; Start Menu > Control Panel > Power Options
You should see something like this.
http://i298.photobucket.com/albums/mm260/mshockey89/Tech%20Support/Poweroptions.jpg
On the left hand side of the screen select Adjust the Display Brightness. You should see somthing like this.
http://i298.photobucket.com/albums/mm260/mshockey89/Tech%20Support/EditplanSetting.jpg
Now just play with the brightness settings until you get the desired effect.
Also, make sure you don't have the brightness settings too low for your off battery settings. This could be a reason as to why your having this issue. If this doesn't fix the problem, let me know.
Jan 03, 2009 | Dell Inspiron 6000 Notebook
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
