Question about Sony Computers & Internet
Sony laptop probz
I have already replaced the power cable, adapter, memory of my sony laptop but still it gives no display, no power at all and only battery indicator is blinking.. i have tested the memory into another laptop and it works fine. hard drive is also working good.
    Sergeant:
    Champion:
  • 221 Answers
This appears to be a Hardware Problem and requires Service Center Care.
Goto www.sahajayoga.org to attain your Self Realization and find a Sahaja Yoga Center to goto.
Posted on Jun 22, 2008
I need a sd card and cable for sony f 717
Your Sony uses a memory stick called Sony Memory Stick Pro which they don't make any more, it was replaced with a smaller card called Sony Memory Stick Pro Duo, go to ebay and buy a adapter called Sony Memory Stick Pro Adapter it is sliver in color with blue color at the end. Once you get ahold of that adapter, you can now buy the new smaller card called Sony Memory Stick Pro Duo and insert it to that adapter, then slide the adapter with the new smaller card into your camera.
I have several older Sony digital camera that I converted to use the newer Sony Memory Stick Pro Duo cards, it works great ! I checked your Sony model on Ebay and you have to scroll down a bit to see those adapters I just mentioned, some sell with the adapter and the newer memory stick already included in the price.
Oct 06, 2014 | Sony Cameras
I can't turn on my la[ptop
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Nov 08, 2009 | Acer Aspire One PC Notebook
Whilst in use went completly dead canot resart
Nov 02, 2009 | HP Pavilion dv6000z Notebook
No' it's not powering up at all now, can you help' after changinng ac-adapter & battery
Oct 19, 2009 | Computers & Internet
I have power out of adapter but laptop is completely dead; no lights come on at all.
Oct 16, 2009 | Toshiba Satellite A45-S150 Notebook
Acer will not boot up even with it being plugged in, no lights, noise, nothing
Oct 13, 2009 | Acer Aspire 5100 Notebook
Dell latitude d500 had a power socket problem, but now resolved pc will not boot-up, drive spins-up, then nothing, completely dead display i think most likely scenario is mobo is fried, but open to...
Oct 10, 2009 | Dell Latitude D500 Notebook
The A light is blinking but the laptop refuses to power up.
Oct 10, 2009 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
VAio VGN-FS742 Screen does not display
Try to remove the battery, remove AC adapter, and press and hold power button for 45 sec. reinsert battery, and Plug and try again, if that doesn't solve it, you may need to try to change memory first, (cheapest) or the motherboard or CPU.
Please give good rating if this helps your issue, Thanks
Apr 12, 2009 | Sony VAIO VGN-FS742/W Notebook
My G733 laptop Internal keyboard does not work and also my supply male pin it's too loose does not electricity. What is the diagnostics step to fix this? Thank for the answer If someday answer this probz I...
Hi there.
The laptop has to be taken apart and a new power supply adapter that fits that model soldered on to the motherboard, you will also have to order the replacement parts first.
The keyboard will probably need replacing, the part number is underneath the keyboard so you will have to remove the keyboard to view it. You can get a power adapter socket from sites like ebay, you will have to search for this part by laptop make and model and is fairly inexpensive to purchase.
Replacing these components will give the laptop new life so if your confident with a soldering iron and know what to do around a laptop motherboard you know what parts to chase.
If you feel your not that confident, you have the option of phoning a reputable PC repair shop and ask them if they can do the repair on the power adapter instead of buying a replacement motherboard, if they can have it repaired by them and also maybe they can do you a deal on a replacement keyboard.
Good luck and thanks for using FixYa!!
Mar 12, 2009 | EliteGroup ECS G733 Notebook
Computers & Internet Logo
52 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
