Question about Fuji FinePix F410 Digital Camera
Fuji Tri-star screwdriver
I have two Fuji F410s, one which works but has a broken LCD and one which doesn't work but has a working LCD display. Should be a simple job if I can just do something with these pesky tri star screws. I can't find a scredriver for these anywhere in the UK. Is there anyone out there who can help me find one?
Here is a link to the tool you are looking for. I live in Canada and found it there.
http://www.nds-central.com/market-wii.htm
Posted on Jun 22, 2008
My finepix z fujifilm camera has burst the ink in the screen so i can't see what picture I am taking - photos are coming out great on computer but now i have accidentally changed the setting to black and...
you can replace the LCD they are 24 dollars on ebay and come with instructions which is a link to you tube video all you have to do is take off back of camera and plug in new LCD not to hard get the kit with the tools you will need a tri- blade screwdriver some screws are anti tampering and you the special tri- blade screwdriver
Jul 12, 2009 | Fuji Finepix Z20fd Digital Camera
Need instructions on replacing brocken screen on fuji A800 camera
Do you have the LCD screen already? If you don't, you can search the internet for Fuji A800 LCD and there are several businesses you can purchase an LCD screen from. Some even offer an LCD screen install service for a few dollars more than the LCD on its own.
If you have the LCD screen or have purchased it, it is usually pretty simple to install the LCDs, HOWEVER! (disclaimer here) the Fuji digital cameras almost always use a weird screw driver, we call it a tri-wing. It is not a phillips and it not a flat head screw driver, but rather, a 3 prong, kind of looks like a piece sign screwdriver. If you do not have this screwdriver, and your Fuji does take this screwdriver, you will have to purchase it as well.
After the case is apart, there is usually 1 or 2 ribbon cables holding the LCD down to the board, gently lift the tabs that hold the LCD and Backlight cables down, and pull the LCD screen out of the camera, and then reinstall the new LCD the exact same way. Make sure if the LCD has a protective film over it, and you don't want the film to stay on it, that you peel that off as well.
Jun 08, 2009 | Fuji FinePix A800 Digital Camera
Screenon my camera is all white but i can still take photos
Try leaving the battery out of it for up to 24 hours, let it fully reset, then try again.  If it still doesn't work, it sounds like the mainboard could be bad - is it still under factory warranty?
May 27, 2009 | Fuji FinePix Z5fd Digital Camera
Z5 flash
uhm mine did to. most definetley ship it in. it's under warranty. if you reset it and it still doesnt work then ship it off.
Mar 23, 2008 | Fuji FinePix Z5fd Digital Camera
Fuji FinePix Z3 camera broken display
Best and cheapest solution is to buy a faulty Z3 on Ebay with an intact outer glass and do a swop. You'll need a tri-blade screwdriver, a very small 4-bladed( posi-drive), and care, but steady hands and a 'follow your nose' plan should see you through. There is a Z3 on Ebay presently to do the job. You can practice on that before you attempt your own. Good luck.
Feb 04, 2008 | Fuji FinePix Z3 Digital Camera
LCD display
This 1.7" LCD is made by AUO and it is most likely defective. You may try reseating the internal ribon cable of the LCD connected to the printed circuit board by opening the camera back case (5 small screws) with a tri-wing screwdriver size #000. Care must be taken as the flash light charging circuit is active and touching certain area of the board may give a big shock once you have access to the internal guts of the camera.
Jan 18, 2008 | Fuji FinePix A350 Digital Camera
How to change a ds case
I swapped one of these into a new case recently for someone following this guide:-
http://site.powergamingparts.com/RepairNDS.html
I'm no expert at fixing things and it was fiddly in places but DS works fine now and looks smart too!
Jan 06, 2008 | Nintendo DS Console
Screwdriver tools
Its a Tri-Wing bit. Just google "security bit" and you'll find hundreds of vendors.
Sep 14, 2007 | Fuji FinePix F700 Digital Camera
Camera won;t work
sometimes on FinePix Cameras, in order to turn on the display, you need to press " |<>|" both buttons at once for the display come one. another thing to try is to press longer on the selection button, that can do the trick, otherwise i would say it's broken, needs to get fixed. There may be one of a number of faults, from the shutter being stuck, to some of the circuitry having died. Either ask fuji how much a repair would be, or ebay it as not-working, for others to pick apart. Good luck
Jan 22, 2006 | Fuji FinePix 2650 Digital Camera
Fuji FinePix F410 Digital Camera Logo
1,015 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
