Question about HP LaserJet 1020 Printer
Its me again (recognition problem)
Hi thank you for asnwering
but the usb works good and the printer don't work in any usb port not a paticular one .
i'm using windows xp
people telling me its a windows problem
so what????????????????
  • HP Master
  • 2,794 Answers
Do you have another USB cable to try it with?
Posted on Jun 22, 2008
After installing the program, the printer still can not work. The suggestion is that the port to which the printer is connected is not supported.Check the port.I want to know why?Thanks in advance
first of all power cycle your printer and your system and then check (first power cycle your printer and then system), if that does not work then go to your device manager and uninstall you USB hub completely and restart your system,by doing this USB driver will get reinstalled and communications between your printer and system will be good again and print will start happneing again.
Aug 25, 2011 | Office Equipment & Supplies
Good Morning! Please help me how to restore the function of my laptop USB port, when i connect even flash drive, printer, scanner to my usb port it dosn't work properly, its hang then when i remove and...
Have you tried to shut down your computer and re-start it up again ? (to see if your USB port starts to works again ?)
One thing you should (must) do before you remove / detach a USB device (e.g. flash drive, camera, etc.) from the USB port is to make sure you properly "dismount" (eject/disconnect) the device first (e.g. use its Property menu option) before you physically remove the device (i.e. take it out - remove it from the USB port). If this is not done, you'll get the problems you're experiencing.
Jan 02, 2011 | Computers & Internet
Whilst printing work out, the printer looses connection with the PC and the PC then has to be closed down so that all works again. Jan
try the followings:
1. use another USB port and re-install driver
2. replace USB cable (if required after step 1)
good luck
pls. vote for better sharing... thank you
Nov 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
USB PORT IS NOT WORKING IN MY CANON PRINTER MP730
hi
check the cord which you are using it may be faulty.
try the usb port with another cord if it does not work, then it is probably you change the usb port.
thanks
Jun 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Unable to get message from computer to printer. Message always appears : "Does not recognize USB port " I have tried all ports. Printer works as I tested on another computer.
Go to BIOS .For BIOS please press del or F2 button on your computer POST .After enter in the BIOS select on board devices or Integrated devices.select USB option and select AUTO option in Legacy USB devices if more than one USB Port then enable all USB port in BIOS.After that if printer not working then pls re-install the printer driver again.
Nov 16, 2009 | Compaq Presario S6000NX (DQ178A#ABA) PC...
Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP 600 cartrige recognition
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 29, 2008 | Office Equipment & Supplies
Canon S450 wouldn't print test page
hi
i first need to know what is the eror message
you need to uninstall\reinstall the printer
this can solve your problem
Uninstall and Reinstall the Printer Driver (Windows) Instructions to uninstall the printer driver
  1. Select 'Programs' or 'All Programs' from the 'Start' menu.
  2. Select the printer driver you want to uninstall, and then select 'Uninstall'.
  3. When the confirmation message shown below is displayed, click 'OK'.
  4. A window showing the progress of the uninstallation is displayed. Wait until the "Uninstall successfully completed" message is displayed.
  5. When the message is displayed, click 'OK'.
  6. This completes printer driver uninstallation.
Note: If you use Add or Remove Program to uninstall the printer driver, the printer model name will remain in the Start menu. To completely remove all files, including the printer model name from the Start menu, uninstall the printer driver using the procedure described in Step 2.
Instructions to install the printer driver for the using the prepackaged CD (Windows) Before installing the printer driver, confirm that the printer is powered off.
  1. Set the prepackaged CD into the computer. (The installer starts automatically, and the following window is displayed.)
  2. Select 'Printer Driver' on the left side in the window, and click 'Install'. (The Printer Port dialog box is displayed.)
    Note: Click 'Readme' to refer to notices on installation.
    Initially, the manual is installed.
  3. Confirm that printer and computer are connected, and turn the printer on.
    Note: To display the explanation about the printer port, click 'Help'.
  4. The Printer port window will be displayed while automatic recognition is performed. (After automatic recognition is completed, the window will close automatically.)
    Note: It may take a while to recognize the printer automatically. If the automatic recognition is not completed, re-connect the printer cable again. If you want to select the port, check Select printer port, and click 'Manual' selection.
    When the printer driver installation is completed, the message below is displayed. (Installation of the manual and printer driver, and the system setting change are completed.)
  5. Click 'OK'.
    Note: If a BJ Raster Printer was previously installed, the following message may appear.
  6. Click 'Yes' to restart the system.
    Note: In the Windows 98/Me environment, if a BJ Raster Printer was previously installed, it may be necessary to re-start the computer in order for the USB port driver to be updated. In this case, click 'OK' to re-start the system and begin the installation process again.
if you are not able to do so write me a email
Jun 19, 2008 | Canon Office Equipment & Supplies
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Usb recognition problems
try plugging the printer into a different usb port,
if it works, the usb port has gone bad
Jan 01, 2008 | HP Officejet J5780 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
