Question about Garmin eTrex GPS Receiver
Elevation Problem When I am at sea level (on the shore) my Etrex shows about 50 elevation
  • junglejim10 Jun 27, 2008
    I have had the same information from Garmin and are satisfied with both what they say and you. Thanking you.
  • Rex Coggins May 11, 2010
    What model of eTrex do you have? Some models have the Barometric Altimeter which needs to be calibrated, and some units do not.
    Vertical Accuracy of a properly calibrated Barometric Altimeter is +/- 10'. If you have a unit that uses provides a GPS Elevation only, a +/- 50' vertical solution is pretty standard.
    Problem Solver:
  • 6 Answers
Posted on Jun 24, 2008
Height above sea level of my house in Southampton
3 metres
Geographic coordinates of Southampton, United Kingdom. Latitude ...
dateandtime.info/citycoordinates.php?id=2637487
Latitude of Southampton, longitude of Southampton, elevation above sea level of Southampton. ... Coordinates of Southampton in degrees and decimal minutes. Missing: my ‎house
Southampton - Wikipedia
https://en.wikipedia.org/wiki/Southampton Southampton is the largest city in the ceremonial county of Hampshire, England. It is 75 miles .... The city walls include God's House Tower, built in 1417, the first ..... [hide]Climate data for Southampton, elevation 3 metres (9.8 feet), 1981-2010 ... The centre of Southampton is located above a large hot water aquifer that ...
Frequently asked questions about Southampton in Queensland - Bonzle
www.bonzle.com > home > homesteads > Southampton
myBonzle menu: Add to my places Add picture Add story Add note. Skip to map ... What is the elevation/altitude/height above sea level of Southampton? Southampton is at an ... Old Parliament House, East Parliament House Picture relating to ...
An Oceanfront Home Built Above Sea Level ' Southampton, House ...
https://www.pinterest.com/pin/172122016986387096/
Southampton · House · House beautiful ... Balconies · An Oceanfront, Southampton Home Built 17 Feet Above Sea Level ...
Height above sea level of my house in Southampton Google Search
Oct 16, 2017 | Computers & Internet
What is the elevation of this above sea level
Of what? You can find the elevation of any location using this great site. http://elevationmap.net/ Elevation maps with altitude finder for any location Altimeter tool
Sep 07, 2017 | Cars & Trucks
What areas of the u.s.a. are lower than 4000 feet above sea level
These links should help you out. 4,000 may be too specific, but I hope you get a good sense from the links.
Geography of United States Low Points
List of places on land with elevations below sea level
Also an FYI;
Badwater Basin is an endorheic basin in Death Valley National Park, Death Valley, Inyo County, California, noted as the lowest point in North America, with an elevation of 282 ft (86 m) below sea level. Mount Whitney, (with an elevation of 14,505 feet (4,421 m)) the highest point in the contiguous 48 United States, is only 84.6 miles (136 km) to the north west.
Feb 02, 2015 | Miscellaneous
Sea level altitude
according to the elevation map its 25 meters or 83 feet above sea level
Mar 18, 2014 | Computers & Internet
HP increase at elevation using a Dyno Jet Dyno?
same dyno? same operator? theres something wrong. the lower altitude the better, as far as I know. But someone thats smarter than me and has high altitude /dyno experience would be better to answer the question.
Oct 01, 2009 | 1983 Mazda RX-7
Is "check engine" light altitide sensitive/dependant
have to wonder. there is definately less oxygen at that elevation so i presume that's what it is. not sure about the rest of the states but i believe california has the toughest specs for pollution control on automobiles. unless of course the motor acts up just ignore the light especially if it goes out when you return to regular elevation.
robert
Sep 03, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Jetting
WHAT MEAN JET? : Carb jetting can be easily understood if we understand the basic principles of carb and engine operation. A carb mixes fuel with air before it goes into the engine. When the mixture is correct the engine runs well. The bottom line is a carb must be adjusted to deliver fuel and air to the engine at a precise ratio. This precise ratio can be affected by a number of outside and inside influences. If you are aware of these influences you can re-jet your carb to compensate for the changes. I'm going to show you some examples of how you can change your jetting for better performance and in some cases increased engine life. As with any engine work be sure you have good tools the correct parts and a good manual before you get your hands dirty! ALTITUDE COMPENSATION: For our first example let's say we find a new riding area WAAY up in the mountains. Our jetting is dialled in for our usual riding area which ranges from sea level to 1500 feet. Our NEW riding area starts at 4000 feet and goes up from there. Going to a higher elevation will require will require a jetting change but which way? Like our fuel density air density can also change. Higher elevations have less air density then lower ones. At high elevations our engines are getting less air so they need less fuel to maintain the proper air/fuel ratio. Generally you would go down 1 main jet size for every 1750 to 2000 feet of elevation you go up (info for Mikuni carbs). If you normally run a 260 main jet at sea level you would drop down to a 240 at 4000 feet. Something else goes down as you go up in elevation is horsepower. You can figure on losing about 3% or your power for every 1000 feet you go up. At 4000 feet your power will be down about 12%-even though you rejetted! For our second example let's say we are still at our new 4000-feet elevation riding area and a storm comes in. We head back to camp and ride it out overnight. The next day there's a foot of snow on the ground the skies are clear and it's COLD!. Aside from getting the campfire going and making some coffee you should be thinking about jetting again! Cold air is dense air and dense air requires bigger jets. If the 240 jet ran good the day before you will need a bigger jet to run properly today. If the temperature is 50 degrees colder,,
Nov 10, 2008 | 2005 Hartford VR 200X
Jetting
Nov 10, 2008 | 2002 CCM 604 DS Dual Sport
Wrong elevation showing garmin etrex vista
Found a fix, by resetting all user data my problem was fixed.
Garmin Edge 305 Power off device and hold 'mode + power'
eTrex Vista Power off device and then hold 'page + enter + power'
Hope this helps!
Dec 16, 2007 | GPS
Garmin eTrex GPS Receiver Logo
224 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
