Question about Jl Audio 500/1 Car Audio Amplifier
500/1 problem My jl 500/1 was hooked up to one 12 on one channel and it blew my speaker now here is the problem i tried to hook up another speaker to it on both channels but the speakers sounds busted and i have tried 3 different speakers that are brand new.
Try while playing the system disconecting one wire from the sub box if the other sub starts sonding better the wires are crossed in the box somewhere switch wires or dismantle box and fix
Posted on Sep 21, 2008
    Problem Solver:
  • 30 Answers
Hi i wish to help u but i will need more info on the type of subwoofers u want to use -are the DVC-or single ...are they 8ohm or 4ohm speakers?
Posted on Jun 22, 2008
How do i hook up an amp to my sync sysytem?
Go to jL audio web link. Thayer have a sound processer that I used in my 2013 ford f150. I have two jl amps 1000-2v and a 500-4v. In the front doors are 6.1/2 jl comp and in back doors are 6-8 jl full range. And two 13" jlpancakes. I use a jl cross over. Hope this helps.
Jun 21, 2014 | Hifonics Car Audio & Video
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    Installin car systems
    you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
    Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
    I want to hook up subs and a amp in a 2008 saturn vue how do i do it
    If you are planning on using the factory stereo you will need a line level converter. You basically connect two of your speaker channels to the line level converter. That in turn will give you a line level out (RCA cables) That line level out can be fed to a two channel amp which would be where your subs would hook up to. If you do this however you will lose two channels of mid range and highs ( your rear speakers ). Downfall to this approach is that some line level converters are susceptible to alternator noise.
    If you have an aftermarket deck this will be much more simple. You simply run your RCA outputs from your deck to your external amplifier. Aftermarket decks typically have front rear and subwoofer outputs. That means you can drive a four channel amp for your front and rear and a two channel amp for your subwoofer. This is the recommended way to go.
    For hookups I just suggest buying an amp kit that is comparable in power rating to your amp. If you buy a 500watt amp make sure your wiring kit can handle at least 500 watts.
    Feb 12, 2010 | Jl Audio M5122.4 Diamond Audio 12" Car...
    Jl audio w7 13 subwoofer system 3ohm driver bridge it 2 ch amp
    How much is your speaker max wattage?
    If it is 750 or below, it can only be used on one channel, either the right or the left.
    If speaker can handle 1500 watts then hook the positive speaker wire to R+
    Hook black negative speaker wire to L-
    Now it is bridged
    Aug 19, 2009 | Jl Audio 13W7 Car Subwoofer
    How do you hookup 2cvr 12 to a mono amp?
    Hook together both positives from each speaker together and both negatives from each speaker together and hook them up as one connection to your amp.
    May 18, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
    Jl audio 500/1 amp low ohm light at high volume
    I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
    So you have + and - running to one channel and + and - running to the other channel.
    Also your LPF filter could be set too high.
    Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
    Jl 500/1
    Sounds like you fried the channel on the amp or your gain might be up to high for the speaker
    Oct 26, 2008 | Jl Audio 500/1 Car Audio Amplifier
    I bought a 500/1 jl audio amp and also a w7 10 sub
    if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
    ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
    this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
    this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
    if your need more help give me your email and ill send you a pic of how to do it...
    Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
    Jl Audio 500/1 Car Audio Amplifier Logo
    130 people viewed this question
    Top Jl Audio Car Audio & Video Experts
    Mark Skinner
    Tygh Duval
    Tygh Duval
    hoyzee1
    Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
