FixYa.com
Tags:
Hotpoint Aquarius WD640 Front Load All-in-One Washer / Dryer
Drier not working
posted by cns39 on Jun 22, 2008
hotpoint aquarius+ wd640 washing ok but drier is not drying at all
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 17, 2008
Not Rated (0)
tresilla
Rank:Guru Guru
Rating: 86%, 1048 votes
take top off. you will see drier manifold going across top of machine with stats mounted on it. one or more of these stats is resetteble ie has a little button in the middle. press to reset. some hotpoint have a thermal fuse mounted on the manifold so if present, check this for continuity as well. with top still off, put on dry and check fan working as well.
if you get it going and fault reoccurs, then there is a blockage in the drier duct
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
Hotpoint Aquarius WD640 Front Load All-in-One...
not drying
My washer dryer does not heat... Answer This...
unable to get door...
I am unable to get in to the... Answer This...
when drying clothes the clothes
when drying clothes the clothes... Answer This...
fitting "Bushes
hi there, Please... Answer This...
hotpoint wd640 front loader
initially went into test mode... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
