Question about Cell Phones
HI I have a Palm treo 650. It has generally been good. then I had a couple of problems 1. I put an earpiece into the jack and from then on I have not been able to use the unit as a handset as the phone speaker doesn't work any more. 2. Today I was waiting for a call. I checked the phone and it was off (despite the battery being half full). Then I tried to turn it on and couldn't. I put it on the charger and tried to turn it on but still haven't been able to Can you please help. Thanks in advance Ian Buckland
Not sure about issue 1 but I fixed issue 2 by taking the battery out for 15 minutes and then putting it back in
Posted on Jun 23, 2008
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
No sound when making calls
Yes, it's a hardware problem. I've seen it many time. The speakers on the Treos are flaky. Get a new phone under your insurance plan.
May 31, 2008 | Palm Treo 650 Handheld
Lost speaker on my Treo 650
This problem usually occurs when the headset jack is busted. If there is sound through the headset but none when you plug it out, then a busted or faulty headset jack is definitely the culprit.
Apr 24, 2008 | Palm Treo 650 Handheld
No sound from my treo 650 earpiece
Try inserting hands-free kit/headphone jack - sometimes immediately after unplugging, the sould will work. This is usually dirt in the jack socket - it's happened to a couple of my Treos.
I sometimes clean the jack socket on my Treo650. You may be able to do this by just removing the battery, which exposes the back of the jack, but I usually remove the case (to prevent spreading dirt inside the device. Once exposed, I spray contact cleaner from the back of the jack socket, with and with out the jack inserted - jiggle it around a bit to flush out any dirt from inside.
Don't insert the battery until the contact cleaner has completely evaporated.
Apr 09, 2008 | Palm Treo 650 Handheld
Help please
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 17, 2008 | Palm Treo 650 Handheld
My palm treo 680 turns itself off repeatedly
hi dear
Good luck
Mar 15, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Wireless headset jack
Sounds like something got tweaked in the socket. If this is still under warranty I would suggest exchanging it.
Mar 03, 2008 | Palm Treo 650 Handheld
Outlook Calendar synchronization failed in palm treo 650
hi dear
Good luck
cropp
Feb 24, 2008 | Palm Treo 650 Handheld
Palm treo 650
The 650 seems to have a delicate headphone/mic jack. Dropping the phone, even gently, seems mess up that jack. I returned my first treo 650 as defective, and got a new one. The same thing happened to my new 650 after I simply compressed the phone in my breast coat pocket by holding my mail against my chest.
I can't get a new one because the replacement treo comes with no warranty of any kind. :(
My advice would be to find a PDA/phone repair service to repair the jack or diagnose the problem if it turns out not to be the jack.
Jan 12, 2008 | Palm Treo 650 Handheld
Treo 650 2yrs old - speaker problem
Hi Michael,
Have you tried volumecare application? Please let me know the result.
Oct 25, 2007 | Palm Treo 650 Handheld
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
