Cars & Trucks Logo
Posted on Nov 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Seat will not move forward or back - Maxima Nissan Cars & Trucks
Anonymous
Level 3:
  • Master 474 Answers
  • Posted on Nov 22, 2010
Anonymous
Master
Level 3:
Answers
474
Questions
0
Helped
125400
Points
1457
Check mechanism that releases seat. Sometimes the wire that releases it breakes or stretches, If this is ok then Spray the mechanism with anti rust spray eg wd-40 Let sit for a few hours the try to move seat gently back and forth.
Drivers not moving
If the controls still work to move the seat up and down and the seat back forward and back then you've ruled out a fuse. The switch could be faulty, could be a broken wire to the motor or the motor itself could be bad.
Power seat
Most Fordicon1.png products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
The long term fix is to remove the seat, disassemble the seat belt guide and rail, and usually replace some parts.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works besticon1.png to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
There's no guarantee that it won't jam again if you move it all the way back or forward, but once you find the right position to hold the seat latch in while moving the seat, you should be able to re-adjust it where you need it to be.
I have a 2005 mercury montaineer. The drivers seat which is a power seat, will not go back all the way. It makes it half way and then nothing. Please help!!!
Most Ford products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works best to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
I have an 03 lincoln navigator the driver seat wont go forward or backward it can only go up and down, but every time touch the switch i hear a click, what can be my problem and what can be done to solve...
Electric seat won't go forward or back. Sounds like it's trying
2helpful
2answers
Manually move power seat
I'm having this same issue, I"m the only one who drives the jeep and its just an extra vehicle, really don't want to put that much money into it if I can just manually move the seat to the furthest back setting.
Power seat control not working to move seat back. works to move seat forward and the other power controls work for seat back postion and such. how can i manually move the seat back. once it is back it can...
that is easy find the motor under the seat that moves the seat back and forth take and neg wire and a hot wire carefully touch the twoo prongs going to the motor after diconnecting the plug going into the motor. it sould go forward one way and croos the wires to get it to go the other way if this works get a new switch and have a working seat.
1998 corvette drivers seat up/down no forward/back
Try removing your seat bottom to access small motor that moves the seat,Tap on seat motors while holding seat switch in the forward position.
10helpful
2answers
My front seat will not move forward. It will recline, move up and down but it will not move forward. I've tried reseting the seat positions but nothing seems to work. my seat wont move forward is there a...
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
