How did you take apart the sceptre monitor? im trying to get it open to see if i have a blown capacitor or 2. It turns on but the led blinks like its in standby mode. I only see 3 screws on the back, otherwise cant get it apart
Had a Sceptre DCL9A model for mine. There are plastic snaps which hold the back and front covers together. After I took off the screws and detach the monitor stand, I slid a very small flat head screw driver along the sides until I found each snap. They should come loose easily with a slight twist of the screwdriver. There are about 5 on each side of the monitor (not counting the monitor). Do not try to force it as you can warp or crack the plastic.
Was this helpful?
Yes
No
Popular Solutions for Sceptre X9G Komodo IV 19 in.
I have a sceptre monitor that will not come on the blue power indicator blinks but there is nothing...
(More)
I have a sceptre monitor that will not come on the blue power indicator blinks but there is nothing on the monitor
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any...
(More)
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any problems. Only have 1.6v at pwr switch, and 5v going to logic side of board. Board is model 490491200100R, can't find any information on this board.
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts...
(More)
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts off. i took it apart and when i lift the glass and put i flashlight behind it i can see that the monitor works but the bulbs are not turning on. is there a way to apply separate power to the bulbs?
