Question about Philips Audio Players & Recorders
I can't find the music on my go gear, yet when I try to re-download the music my windows media center says that the music is already on the device.
  • 8,596 Answers
The songs are in the wrong format - it will accept some WMA files but not others - Windows Media Player will appear to load them but they will not actually show up on the GoGear. Convert them to Mp3, and they will load fine.
Posted on Jun 22, 2008
Windows Media Player has stopped playing/burning?
try to read first Windows Help and support.
search for Burn a CD or DVD in Windows Media Player
or look link Microsoft Community Microsoft Windows
Dec 19, 2014 | Microsoft Windows Media Player
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
I am trying to sync music from a cd that is in my windows media player library to my ipod touch, but my computer or media player is not recognizing a device connected in order to sync the music..
you can not sync an iPod with windows media player. if you wish to add the music to your iPod, the only way is to download iTunes.
if you already have iTunesyou
*open iTunes
*insert cd into computer
* a notification will pop up. and you need to download the songs into your library.
hope this helps -_-
Jan 09, 2010 | Apple iPod touch
Bought a gpx8gb digital media player for my daughter for christmas. I have downloaded her cd's into itunes library. Now how do I get those songs onto her media player?
Check to see that when you rip a music CD that your music is not copy protected. The RIP function in your Windows Media Player will allow you to convert the music CDs you have purchased into either an MP3 or a WMA format.
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Choose the type of music file as well as the quality with which you would like to save the music. (Your GPX player has the ability to play music files in both the MP3 and WMA format.)
  4. Make sure to use MTP when transferring copy protected WMA files.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
  1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In Device Setup - Configure Sync, write a name for your mp3 player.
  3. Click Finish. The window closes and the Sync feature in the Player is displayed.
  4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
  5. Select the songs or entire albums from the center pane.
  6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
  7. Click the Start Sync button on the Sync List pane.
  8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
  1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In the Device Setup Wizard, select Manual.
  3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
  4. Select the Library option. On the left pane select Sync List.
  5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
  6. Select the songs from the center pane, and drag them to the Sync List.
  9. Good Luck, I hope this helps
  10. Please rate me, Thank you
Dec 09, 2009 | GPX MW3836 MP3 Player
When I download music into my zen mp3 player I use windows media player it deletes all the music thats already in the mp3 player how can I download more music without it deleting what is already in there?
go into windows media player while your zen is connected and under tools, options, devices click on your zen and under the properites button there will be sevral options that may be enabled that say something like delete music before sync or something like that poke around in there i know the options there
Sep 25, 2009 | Creative Labs Zen Digital Media Player
Loading music on gpx mp3 player
go to poilit or some your commfortable with. down load to pc the stuff u want, then move this to your windows media center plug mp3 to your pc. then open media center it will ask download to device or cd clik device and it will do the rwest
Mar 29, 2009 | GPX MW6347DT MP3 Player
My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
Sep 11, 2008 | Philips GoGear HDD1830 MP3 Player
Lost software for my Phillips GoGear
www.usasupport.philips.com enter country/language entry model number click on model # click on software & drivers
-Tha Mp3 Doctor
Aug 20, 2008 | Philips GoGear HDD6330 MP3 Player
Where do i get the program to install music on my go gear 1630
You should try using Windows Media Player, I'm giving you guys a link too Windows Media Player 11, but you can get a lesser verson. If you already have windows media player. You should be able to SYNC music from your computers music library into your mp3 player! I hope this helps.
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Nov 05, 2007 | Philips HDD1630 MP3 Player
GPX MW3337 sync problem
1- Check that your MP3 Player's File system is OK, you can do that using the DOS command (chkdsk /f). 2- Re-install your Windows Media Player 11. 3- Don't forget to update your system, too.
May 30, 2007 | GPX MW3337G
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
