Needs new caps on power supply.........easy fix...
I have the same problem, initially no power at all, replaced 14 capacitors on PSB. Now I get a click and the green light comes on but can't get a picture or sound. Every ten seconds or so, there is a click from the tv, like a hard drive trying to start?
sounds to me like power supply.............can you check that all the caps are fitted right way round ? the pcb does show how they should be fitted.........also check for dry solder joint......
cheers
Spot on pjhislay1 two of the caps wrong way round, one dry joint. Sorted that out and powered up, backlight came on, then got "no signal" message. Went into menu and retuned chanels and now everything working perfect. The only thing I can't get to work at the moment is Sky from the hdmi lead but it probably just needs tuning.
Many thanks for the help.
Cheers
Mel
your welcome..........cheers paul.
All the internal parts you need to repair this model are available here:
Search results for 32LX2R
