Question about Teac A-H300 Amplifier
No power Hi, A friend recently borrowed this amp for a party. It came back dead. He eventually told me that he'd been using it at full volume when suddenly everything went dead. Is there a thermal cutout inside? If so is there anything I can do to sort it out? Thank you - Jayne
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi chiclana
    Never ever lend stereo gear to mates for a party.I wont even hire gear to them for that. Ask them why they need it, and so often they will say" because I dont wont to blow up my own!!"
    A few things to ask you
    1. Does the unit have any power at all?
    2. can you check for any blown fuses
    3. is the unit still covered by any warranty
    Please let me knowand we can go from there.
    robotek
  • 1,512 Answers
Hi Jayne, How did you go with the amp
robotek
Posted on Jun 29, 2008
Volume is at maximum, have tried resetting, unplugged and plugged back in. Had a power surge prior to the problem?? Can this be fixed?
Are you trying to say you have NO SOUND? Is the power surge comment a statement or a question?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Mar 04, 2011 | Motorola DCP-501 Receiver
I have an Onkyo receiver where I am not getting any sound from the speakers unless I have it turned all the way up. It does not matter if it is on CD, Tuner, Tape 1, or Video. There has not been any...
What sound do you get at MAX output? If it's anything like the desired program, you probably have a switch out of position somewhere. Blown amps are usually dead silent.
Feb 27, 2011 | Onkyo Audio Players & Recorders
My onkyo tx-8222 suddenly stopped amplifying on both speakers and headphones. I can hear music faintly with the volume at max (just the pre-amp?). Time for a new amp?
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Feb 21, 2011 | Onkyo TX-8222 Receiver
No sound output from my pioneer vsx-1014k using either CD, tuner or home theater inputs.
IOW, no audio from anywhere.
If it otherwise looks alive...
WARNING: Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Jan 19, 2011 | Pioneer VSX-1014 Receiver
Power went off and came back on last Friday and now tv wont turn back on
Have you got a stand by light on, or is tv dead totally.I would Check plug fuse if dead, My suspect would be power supply capacitors drying out (had this fault recently with friends tv) this caused tv to be working sometimes but eventually stuck on standby. Capacitors are cheap but not a job for the novice.
You could ask local tv shop for estimate
pete
Nov 08, 2010 | RCA L37WD12 37 in. LCD HDTV
I am not a verison customer..How can I get unlock code ? I asked verison for the code but i was told they couldn't do ti unless I was a customer. So I asked them why if it could be done through a 3rd...
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
Apr 26, 2010 | RIM BlackBerry Storm 9530 Smartphone
Issue with the monitor
well
borrow a monitor and thy that.
or move your pc to a friends good monitor and try that.
or more easy
press button 2
if the OSD menu id dead the monitor is dead.
http://www.manualsdir.com/manuals/68175/compaq-mv-740.html?page=8
if that test passes. then the PC is sick
but no PC told.
nor OS
Jun 04, 2017 | Compaq MV 740 17" CRT Monitor
Red light on my amp?
Does the amp power up normally if you disconnect the speaker wires from the speaker terminals of the amp?
It's never a good thing to blindly short across a power source.
May 22, 2008 | Pioneer GM-5200T Car Audio Amplifier
Car ausio amplifier
Power up the amp with the volume set to the minimum. Does the amp start to heat up?
What model is the amplifier?
Oct 15, 2007 | Alpine MRV-F345 Car Audio Amplifier
Flashing volume control
THE MUTING CIRCUIT IS ON AND IT CANNOT BE DEACTIVATED BY UNPLUGGING UNIT...YOU MUST HAVE THE REMOTE TO DEACTIVATE.
Sep 10, 2006 | Yamaha DSP-A1000 5-Channel Amplifier
Teac A-H300 Amplifier Logo
161 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
