Question about Whirlpool Duet GHW9150P Front Load Washer
WATER PUMP I DON'T GET AN ERROR CODE BUT I CAN'T WASH IN COLD WATER. WHEN I TURNED OFF HOT WATER. WASHER DIDN'T HAVE NO WATER COMING OUT AND NO FLASHING LIGHTS.
  • 57 Answers
Your water valve is bad replace that and you will be set to wash cloths again
Posted on Jun 24, 2008
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
I have code fh
Hey Lukec,
The FH error code on your Kenmore Elite washer indicats that there is a problem with in-coming water flow. When the water feeding the washer is less than what it should be, the FH code will trigger and the washer will shut down.
You can check a couple of common problems that can manifest this error code after resetting the machine. Steps for reset and diagnostics can be found below.
  1. Using the "Pause/Cancel" button on the washer control panel (this button will be below the digital time clock, to the lower right of the wash cycle selector) by pressing the "Pause/Cancel" button twice to cancel the wash cycle.
  2. Next, unplug the washer from the wall socket (this will reset the error code).
  3. Several things you can do to troubleshoot the follow issue are these:
    Check for kinks in the water supply hose.
    Turn off the water supply (hot and cold) and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  4. Reconnect the water supply hoses to the washer and turn on the water supply.
  5. Plug the washer cord back into the wall outlet.Select the wash cycle and press the "Start" button.
If the error code returns, you will likely have internal water flow issues due to the pump or other internal problems which may require a service technician.
Hope this helps.
Oct 03, 2014 | Kenmore Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
My Amana LW9203W2 washer will not fill. When a cycle is started, it goes straight to agitating. The error code it provides is 6P. I'm assuming this is the pressure switch, but I don't know if...
Try this first!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 20, 2011 | Amana Washing Machines
I have a fisher and paykel washing machine.Its started leaking under the machine when its do the rinse.
The leak could be from:
  • the pump
  • one of the hoses that attaches to the pump system
It is likely to be the pump. However, to verify where the leak is coming from do the following:
  1. Make sure the washer is empty of excess water. (Run the Spin cycle, if not sure.)
  2. Unplug the washer.
  3. Turn off the hot and cold water supply taps.
  4. Disconnect the hot and cold water supply lines.
  5. Pull the washer away from the wall a couple feet.
  6. Have a helper tip the washer back toward the wall and hold it up securely for you!
  7. Get down on the floor with a flashlight and look up underneath the washer for the pump. It will have a small fan blade as well as wiring and water tubing going to it.
  8. If you see signs of rust or water drops on the pump, the pump impeller shaft seal is probably leaking. Order a new pump and install it. It takes no tools and about 20 minutes as follows...
  1. Get a roll of paper towels.
  2. Make sure the washer is empty as above.
  3. Unplug the washer.
  4. Turn off hot and cold taps.
  5. Disconnect hot and cold supply lines.
  6. Pull washer away from the wall a foot or two.
  7. Tip the washer back toward the wall.
  8. Have a strong, reliable helper hold the washer in that position -- firmly against the wall.
  9. Get down on the floor. Lie on your back and put your head and arm under the washer (that's why you need a good helper!).
  10. Unplug the electrical wiring to the pump. (The GWL11 has 2 wiring connectors.)
  11. Slide a shallow plastic dishpan under the pump to catch any water.
  12. Find and bend back slightly (don't break it!) the plastic retaining latch that holds the pump in place.
  13. Rotate the pump counter-clockwise about 60 degrees, until it comes free.
  14. Note the angle/position of the pump as you pull it free. This is the same angle/position you'll use when you put in the new one.
  15. Have your helper clean up any excess water that ran onto the floor.
  16. Install the new pump.
  17. Have your helper lower the washer to the floor.
  18. Reconnect the washer to the hot and cold water supplies.
  19. Open the hot and cold taps.
  20. Plug in the washer.
  21. Test the washer with no clothes in it.
BTW - Cleaning all dust out from under the washer a couple times a year should help prevent pump squealing and leaking in the future.
May 30, 2011 | Fisher Paykel EcoSmart GWL15
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When Istrted to wash my cloths , the washer stop and post F-20
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
drain_inlet_hose_wall.jpg Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No Cold Water Wash; Only Hot
When doing a hot wash the machine is designed to take both hot and cold water. This is because it can heat the water to your selected temperature but if the water coming in is too hot it needs to cool it down to avoid heat damage to your laundry.
Hope this helps & thanks for using Fixya.
Dec 18, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
