Speaker ends to connect speakers to my used stereo
I need to find the ends that could be put on the end of wires to plug into my used duraband stereo/cd player. Mine where chopped of accidently.
Can you help me from the company itself?
Thanks Cindy
319-795-7290
SOURCE: Panasonic CD PLayer SL-CT520 Rechargeable AAA Batteries
Dear Anskho8,
The best guide for batteries is the type Size, voltage, and capacity in milliampere hours. as long as this specifications match you can always interchanged them. However you should buy the same type and quantity per batch, do not mixed them up.
Also make sure these are NI-mh types.
sid
Posted on Nov 21, 2007
SOURCE: SA-AK330 CD stereo system: how do i connect speakers to receiver?
There should be four colored wires let out from each speaker. connect the wires to the color coded posts , left and right as marked. the small loop antenna is for am and the t-type antenna is for fm. the manual for this unit is also available on the web. key in your model into the keyword window. good listening to you.
sfkling
Posted on Jan 19, 2008
  • 10 Answers
SOURCE: pioneer pl 200 , no sound well real quiet
The third wire is a ground wire I think. You are running the ttb through a phono input and not through a line level input on your system right?
Posted on Nov 17, 2008
  • 7 Answers
SOURCE: pioneer car stereo-how to hook up speaker wires
ok u have 8 wires because the other wire is just a ground.as long as u ground the other wires u should be fine. ok the wire that is marked ign. wire may be your mem.wich usally hooks to an orange wire the hot wire u have is just what it says hot that comp. at the end i blieve was a fuse .it sounds like the other part is missing.
Posted on Apr 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Installing a 10uf capacitor along a speaker wire, no sound
Way too low!!
Your cap should be up in the 200mFd range.
CLICK HERE for a calculator - since it in unclear whether you are using a component set as in the selected item - or a single speaker.
put your impendence in of the woofer, and the crossover frequency you are wanting to achieve.
Then use the first or second order cap. value.
Thanks for using fixya - a fixYa rating is appreciated for answering your FREE question.
Posted on May 29, 2009
What do I need to connect the GPX HT12 2.1 speaker system to my tv
If your Tv has audio out terminals, buy long enough RCA cables and connect the other ends to the lower GPX (main unit) terminals and the others to the TV. If it doesent,get a 3.5mm stereo plug (like you use with portable devices) WITH 2 RCA PLUGS at the other end. Connect the 3.5mm to yourTV's earphone connector and the other end like I previously described. The satellite speakers have their own leads which are connected just above the audio in terminals.
Feb 15, 2015 | Audio Players & Recorders
I connected a after market stereo in 2000 yukon the stereo turns on but no sound comes out and the stereo good what might be the problem?
If you got the stereo used the speaker wires might not work. I stereo only puts out sound thru the RCA output using an amplifier.
Aug 18, 2011 | Chevrolet Tahoe Cars & Trucks
Cant figure out how to hook them up
Two audio input cables are supplied with the speakers. If your computer has a stereo mini jack, use the cable with a stereo mini plug. Otherwise, use the cable with RCA plugs on both ends. Match the colors on the connectors to the colors on the jacks, red to red and white to white.
The speaker cable is already attached at one end to the accessory speaker. Plug the other end into the TO ACCESSORY SPEAKER jack on the powered speaker.
1. Connect one end of the audio input cable to AUDIO INPUTS A. 2. Connect the other end to your computer's AUDIO OUTPUT jack. We recommend using LINE OUT if your computer sound card offers more than one option. 3. To connect a separate CD-ROM, or another source, repeat steps 1 and 2 using AUDIO INPUTS B.
You must connect the AC power pack to operate the speakers. 1. Plug its cable end into the power jack on the powered speaker. 2. Plug the power pack blades into the wall outlet. 3. Turn on your computer sound source or external sound source.
Jun 27, 2011 | Bose MediaMate Computer Speakers
Can you put a newer radio in a 2001 yukon
Hi, my research indicates you can install a single din aftermarket head unit in the 2001 Yukon.
A couple of good websites to use are crutchfield and modifiedlife.
Crutchfields will identify exactly what adapters are needed, and modified life has the factory wire colors.
You will need an adapter to fill the space between the aftermarket stereo and the hole left by removing the factory head unit.
You will also need an antenna plug adapter.
I recommend you buy the wire harness pigtail to simplify the installation--this may or may not include the antenna plug adapter.
If you have onstar, you will need an additional adapter.
If you have steering wheel controls, you will need another adapter to keep those.
Keep the above things in mind when selecting a new aftermarket stereo, as you will need one that is compatible with steering wheel controls and onstar, if you have either of those and want them to continue to work with the new stereo.
Crutchfield has an link called "outfit my car" that takes you through a "Turbo tax" style questionaire and tells you what will work and what you will need. here is the link: http://www.crutchfield.com/App/Car/outfitmycar/MyCar.aspx
Assuming you have a base Yukon, here are your factory wire colors from modifiedlife.com:
2001 GMC Yukon Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Please let me know if you have questions, and thanks for using FixYa.
Jan 18, 2011 | 2001 GMC Yukon
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Hey there I have Dell 5650 Computer Speakers i turn the volume all the way down but still get high sound from speakers someone please help
how long has this been going on? you can also turn the volum down on your computer look to the lower right corner of you monitor. you will see a little horn. double click it to bring up your volum control lower as needed
Nov 13, 2009 | Dell 5650 Computer Speakers
I have a 1993 chevy lumina that I want to put a Clarion radio in, the original was stolen along with the wiring harness, so I only have bare wires exposed, what parts do I need to purchase?
You can purchase a small package of crimp connectors for the electrical connections. If the wires are exposed, you can connect them using this following list of connections.
These are the CAR's wiring (not the radio unit)
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Look on the owner's instructions for the radio, the wiring diagram should be there. If not you can visit the clarion website with the radio model number to get the color codes for the radio wiring..
Simply crimp each to the correct corresponding wire. You may have a few extra.. the antenna power, or the radio mute.. just cap the ends of these..
K
Sep 17, 2009 | 1993 Chevrolet Lumina
I don't know how to attach my speakers to the red
If you have bare ended wires , you simply unscrew the red and black plugs at the amp they should have a hole in the end of the plug and on the side also just place the red wire into the side hole of the red plug and finger tighten the red screw the same on the black plug
Jun 06, 2009 | Polk Audio RTi100 Main / Stereo Speaker
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
 Grubhead
Grubhead
