Question about HP Color LaserJet 2600n Printer
Magenta cast over whole page
I have an HP 2600n. Every page I print has a magenta cast over the whole page. It is using up all of my magenta ink. This in an HP cartridge.
How do I stop this.
  • 22 Answers
IF IT WERE A 4600 SERIES THAT WOULD BE THE DC CONTROL BOARD
Posted on Jun 24, 2008
Hp CLJ 2600n colors problem
do a permanent storage init reset
Feb 13, 2014 | HP Color LaserJet 2600n Printer
I am using the HP Laser Jet 2600n and I only use the black ink, I have it set up that way, for financial reasons. Why is it not letting me print? It is saying that my magenta is out, and will NOT let...
First of all, for financial reasons you don't use a color printer. Unless you print graphs.
Second of all, this is a laser printer, it doesn't use ink.
Third, all four toner cartridges must be inserted and working in order to print in any color.
Go back and read the "First of all" again and buy a B and W laser printer.
Dec 07, 2010 | HP Color LaserJet 2600n Printer
Hello, I have HP lj 2600n. It does not
the problem is due to scanner mirror dust.you have to clean the scanner mirror.
Oct 26, 2009 | HP Color LaserJet 2600n Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
HP 2600N LASER PRINTER
You can try going into your print settings/preferences and checking magenta only. printers you need to keep a watchful eye on your ink levels, because if you are out of ink, you can not print in ANY color, even black.
If the above thing not works You can begin by making sure you are not using anything above 24-bit colour (RGB) in Word.
Also: Word does not use a colour profile. It doesn't make any changes to
the colour, so it doesn't compensate at all. The only colour profile
between Word and the printer is your Printer's colour profile.
Hope this helps
Sep 19, 2008 | HP Color LaserJet 2600n Printer
Magenta covers entire page
I had a similar problem. See: http://www.fixya.com/PostQuestionTx.aspx?prdid=378544&ctgid=0&thid=1044936&type=2
Are you your replacement cartridge orignial HP?
I also had your problem on my previous HP printer (don't remember the model #). And I had it cleaned a couple of times, replaced the magenta cartridge (but with remanufactured), and could not get rid of the magenta. I gave up and bought a new 2600n, but now I wonder if I had used original HP parts if the problem would have been solved.
Sep 13, 2008 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
Printer adds pink to whole page
Try to uninsall the sofware, and insall again...
Feb 21, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
251 people viewed this question
Ben Johnson
