Question about Kodak EasyShare C613 Digital Camera
Kodak c613 power issue
I have used my camera for about a week, and now, it powered on for about 5 seconds and the backlight on the screen went off, the lens came out during this time, i tried to power it off, and it did, then the lens stayed extended, but the camera itsself will not come back on
  • 2 more comments
  • Anonymous Jun 30, 2008
    your problem also happen at my camera, after 5seconds my camera suddenly off
  • Anonymous Jul 24, 2008
    lens is still stuck out, new batteries didn't help at all, don't know what else to do
  • jazzeepooh08 Jul 31, 2008
    i have put new batteries in my camera it will come on and shut off and the lenses wnt go back in after it cuts off!
  • rhs02006 Oct 11, 2008
    Yes! same problem. It's definitely not the batteries, because when the batteries are low in the past, it gives a warning and then powers down. No warning this time, just turned off and the lens stayed open...
Batterys??
Posted on Jul 01, 2008
Hi, My Kodak EasyShare C613 intermittently starts up ok, but other times the lens extends and the viewfinder stays on the initial screen. (The Kodak EasyShare system 'share') After around 40 seconds...
My camera is stuck on the screen that says "lens error" and then has four different numbers in a row. The camera lens is fully extended and will not shut off...any suggestions of what the problem could be?
Nov 04, 2010 | Kodak EasyShare C613 Digital Camera
Can I use Ultimate Lithium batteries in my C613 Kodak EasyShare camers or they to powerful?
No, the recommended battery for your C613 camera is the Ni-MH battery. It will give you stable power on your camera.
Feb 09, 2010 | Kodak EasyShare C613 Digital Camera
No power on camera Kodak C613 digital
use a rubber eraser to clean the ends of the batteries and the contacts in the camera. this will allow for more power to pass and might help. also make sure contacts are not bent down too far.
Dec 15, 2009 | Kodak EasyShare C613 Digital Camera
Kodak C613 will not turn on.
try to clean battery contacts with soft cloth and then replace batteries. If you have a dock, see if your screen powers up without batteries but on the dock. Fixed our similar problem.
Dec 19, 2008 | Kodak EasyShare C613 Digital Camera
The camera wont turn on
The camera will not come and I change the battery. The camera want come back on.
Nov 23, 2008 | Kodak EasyShare C613 Digital Camera
Same problem with kodak c613
Well unfortunately you may not be able to use my problem solve...I took it back to Best Buy since I was within my number of days limit to return! I have read on other sites however that using Kodak batteries has solved some people's issue - that seems ridiculous to me since they should be the same as Energizer, Duracell, etc., but I guess it's a cheap alternative to give a shot. Sorry I am not of more help!
Oct 12, 2008 | Kodak EasyShare C613 Digital Camera
Kodak c613
it is a common problem for the c613 not turning on. what you can do is use rechargeable batteries for your camera. Alkaline batteries can cause power issues. Make sure that the batteries are inserted correctly.check your manual for proper battery orirntation.if this does not resolve the issue, send cam for repair.
Jul 06, 2008 | Kodak EasyShare CX7430 Digital Camera
Problems downloading pics
skip the whole process and buy a sd memory card reader-it's plug and play- no software and will save your batterys when you download-they work great and bypass the issues your having-plug into usb port and will download to xp or vista
May 20, 2008 | Kodak EasyShare C613 Digital Camera
Kodak c613 will not switch on put in new batteries had this camera since xmas
use rechargeable batteries with your camera.alkaline batteries can cause power issue. Make sure batteries are inserted correctly, please check manual
Feb 27, 2008 | Kodak EasyShare CX7430 Digital Camera
Kodak easyshare c613
Are you using Lithium batteries?
Most Kodak models are only happy running on Lithium batteries.
I have two Kodak cameras, both had various power-related problems. Since using Lithium batts, not a single glitch.
They are more expensive, but they end up costing less compared to the amount of alkaline batts replaced.
Worth a try.
Jan 01, 2008 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
189 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
