Question about Toshiba Computers & Internet
I cannot connect to my wireless network connect
  • 144 Answers
Try Re-Instaling the drivers/ try re-inserting the card/ insert in another slot/ test on another PC.
Posted on Jun 22, 2008
How do i reset it my wireless adapter
If I were you, I'd first let Windows Manage Wireless Network Connections:
  1. Click Start If you're using XP, click Start then open the Control Panel. Find the Switch to Classic View button in the Control Panel and click it.
  2. Open Network Connections Open Network Connections then double-click the Wireless Network Connection icon.
  3. Click the Properties Click the Properties button. Look for the boxes at the bottom of the Properties window that read "Show icon in notification area when connected" and "Notify me when this connection has limited or no connectivity" and make sure they are both checked.
  4. You could also right click on the Wireless Network Connection icon and click Properties from there.
  5. Open Wireless Networks tab Open the Wireless Networks tab and make sure the box labeled "Use Windows to configure my wireless network settings" is checked. Then click OK.
  6. under Control Panel\Network and Internet\Network and Sharing Center you could find "manage wireless connection" there you could assign/delete wireless connection.
Oct 26, 2014 | Lenovo ThinkCentre M72E 4004-B8U Tiny Form...
Tip
How to connect to a wireless network with windows xp (must have a wireless...
  • In the start menu, click "Control Panel"
  • In the Control Panel window, click Switch to Classic View. If the text reads Switch to Category View, then you are already in Classic View and can skip to the next step.
  • In the Control Panel window, double-click Network Connections.
  • In the Network Connections window, right-click on the appropriate wireless network connection, and select View Available Wireless Networks.
  • In the Wireless Network Connection window, select your Wi-Fi (SSID)"Connect".
  • If you don't have a security code on it then In the Wireless Network Connection warning dialog, click "Connect Anyway" .
  • The Wireless Network Connection window will first indicate a status of Acquiring Network Address for your Wi-Fi, and a few seconds later will indicate a status of Connected. You are now connected to your router and can close the window.
on Jan 18, 2010 | Computers & Internet
Satellite p35 will not go to wireless
Might not have a wireless card installed ??
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop.
However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings."
This will give you options for modifying how you connect to the Internet.
Select "Connect to a Network" or "Show Network Status and Tasks."
Both selections will show you whether you are disconnected from the wireless network.
Select "Manage Network Connections."
This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection.
Engage the wireless connection.
Turn your wireless switch to "On," then right-click on the wireless network connection.
Select "Connect/Disconnect."
Wait for the IP address acquisition.
It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address.
When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength.
Launch your favorite browser to access the Internet using the wireless connection.
http://forums.computers.toshiba-europe.com/forums/thread.jspa?threadID=18365
Aug 25, 2013 | Computers & Internet
Enable wireless capability
Certain models of Acer desktop computers are designed with wireless capabilities.
These capabilities can be added to an Acer desktop system that does not connect wirelessly with either an internal or external wireless card, depending on the computer's configuration.
When the wireless connection is not working properly, you can troubleshoot the issue yourself.
The troubleshooting process eliminates the problems that may be preventing the Acer desktop computer from connecting wirelessly.
Check to see if any other computers at the same location are able to connect wirelessly.
The issue may reside with the wireless router or access point.
Power cycling the router or access point may resolve this issue.
Verify that the wireless adapter is enabled.
Click the "Start" button, then "Control Panel."
Click "Network and Sharing Center," then "Change Adapter Settings."
If the wireless adapter is disabled, right-click on it and select "Enable."
Connect to the proper wireless network.
The Acer may be attempting to the connect to the wrong wireless network, or it may have lost its connection to the correct network.
Click the wireless network icon in the task bar.
Click the proper wireless network, then click "Connect."
Enter the network password (or WEP key) if prompted.
May 26, 2013 | Acer Aspire Computers & Internet
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
New wireless network trying to connect to unsuccessfully
Try going to Network and Sharing Center - Manage Network Connections. Click on the connection and enable it.
Also try Network and Sharing Center - Manage Wireless Connections, and moving the wireless connection you'd like to use and move it to the top of the list. Select any operations that will enable or connect to the network.
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
When I try to run the Dell Wireless Configuration Utility from the control panel I get the following error message:"The wireless network adapter could not be accessed. This application may have diminished...
Well Sir in this case i will advice you to disable the Dell Wireless Configuration Utility and instead use windows utility for a successful connection.
For disabling dell configuration utility follow these steps:-
1)Open dell Wlan utility , it will have five tabs at the top labeled wireless networks , link status , site monitor , diagnostics and information.
2)Click on wireless networks tab and uncheck the first option which says , "Let this tool manage your wireless network" then click ok or apply at the bottom right-hand side corner of the screen.
To Enable Windows Utility for Windows XP follow these steps:-
1)Open the Control Panel from the Start Menu.
2)From Control Panel click on network and internet connections and then open network connections from there.
3)Right-click Wireless Network Connection and choose Properties.
4)
Click on the Wireless Networks tab and if unchecked , then check the box for Use Windows to configure my wireless network settings. Then click OK.
5)Right-click on Wireless Network Connection, Select View Available Wireless Networks.
6)
This will lists all the available wireless networks in range. Select your network from the list and click Connect.
7)If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key(which is the password for the wireless network) and then click connect.
8)Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wireless.
This Link will guide you through the steps:-
http://kb.netgear.com/app/answers/detail/a_id/111/kw/wireless%20zero%20configuration/r_id/100109
Nov 24, 2009 | Computers & Internet
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
I have a Toshiba Satellite Notebook and I'm having a problem with the wireless router network connection. When I go to the wireless network connection, no wireless networks are found in range. I try to...
sm times wireless network did not respond due to wrong setting in internet connection setting....
checked it out.....
see nother lptop which recieve wireless network n do urs setting same as that....
than connect wireless network u will be able to connect it....
ask me if it creates more problem.....
also available for live chat.....
Jun 22, 2008 | Toshiba Computers & Internet
Carnt get the wireless connection to work on new laptop
Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 29, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
