Integra DTR 5.8 --- NO Audio.
No audio at all. You can hear a little bit of static on the speakers. When you turn up the volume one or more of the speakers will make a low db popping. Test tone will not even come thru. I checked 5 fuses inside the recevier. All where good. Where do I go from there? All video inputs seem to be fine. OSD works. Thanks in advance for any help.
  • 17 Answers
SOURCE: No OSD on TV connected thru composite video (Monitor Out)
for the tx-sr606, the onscreen display will only show up when you connect the receiver using HDMI out to your tv. this is indicated on page 22 of the user manual.. hope this helps.. ^_^
Posted on Nov 28, 2008
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
Zacnickp
  • 33 Answers
SOURCE: I have an integra dtr 7.7 receiver which when
obviously a short somewhere in the system....
you know what i would do?
pray to god you are still under warranty! XD
its a beautiful machine....
Posted on Jan 08, 2010
SOURCE: the reciver dosnt get a signal from the hdmi
HAVING THE SAME PROBLEM. omg. maybe there is help. will get audio but no video from DPS dvd player and PS3. no onscreen menu either. changed hdmi cord. seems to be problem with reciever. DVD works fine when changing to component cables instead of the HDMI. sometimes plugging and unplugging the HDMI cable gets the PS3 working. Don't quite understand scrap605's suggestion. but that doesn't solve this prob.
Posted on Mar 07, 2010
gopakumarg43
  • 75178 Answers
SOURCE: We hooked up our Integra
Hello
The DTR-5.2 contains an internal microcomputer that performs
high-level operations
Reset the device to its factory settings. Before doing that check the following 2 items.
[1] Input selector may not set properly.
Set to correct input source
[2] Headphones are connected.
Lower volume and then disconnect headphones
To reset it to factory settings:
To reset the surround mode and other settings to the factory
default settings, hold down the Preset Memory button with the
DTR-5.2 turned on and then press the Standby/On button.
"CLEAR" appears in the front display and the DTR-5.2 enters
the standby state.
If this also does not help; service is necessary to your set. Contact nearest Integra/Onkyo authorised service center. This is not any component fault. A service only necessary. OK.
Posted on Jun 26, 2011
I am not getting any audio (sound) out of my Integra DTR 4.6. Any suggestions?
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Oct 15, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
Integra receiver clicking
You most likely have a power amp problem, disconnect all speakers and see if still does the clicking, if so you have an output amp problem
Apr 01, 2014 | Integra DTR-5.1 Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
Onkyo integra dtr 6.8 protrection problems
The audio output stage has load issue, check speaker wires for shorts, if okay! the problem is in the semiconductors and this is where a professional is needed.
Apr 03, 2012 | Onkyo TX-SR605 Receiver
Turn on receiver and turns off immediately dtr-5
I have the same problem! Could you fix it
Oct 13, 2009 | Integra DTR-5.1 Receiver
Jun 30, 2009 | Integra DTR-5.2 Receiver
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
Volume control unstable
You may have an over heating problem as it the Integra has anautomatic cut out. The unit generates a huge amount of heat and needs to be positioned in a very well ventilated position.
Linian
Dec 11, 2007 | Integra DTR-5.1 Receiver
Avicn2
The guy on Ebay will fix Avic N-series audio problems for around $110 plus shipping.
Sep 07, 2007 | Pioneer AVIC-N2 Car DVD Player
163 people viewed this question
 Grubhead
Grubhead
