Question about Intel Motherboard
D845SVR mobo - no boot
This mobo does not boot up. No beeps. No display. Tried changing the RAM with new one. No Luck. Even after removing RAM - No beep. Please help..
  • 2 more comments
  • Anand Salunke
    Anand Salunke Jun 22, 2008
    Yes, the fans spin. & power Green Lights & HDD lights turn - on. but no display..
  • Anand Salunke
    Anand Salunke Jun 23, 2008
    I have tried on another monitor, no luck.
    I have reset BIOS many times, replaced the cells. Checkd the thermal greese on CPU, its OK.
    I have tried adding a VGA card also. But no Luck.
    I have replaced the CPU (Intel P4 - 2.8 Ghz). But no Luck.
    I have replaced the RAM, No luck
    I have cleaned the RAM slot, but no luck..
  • Simon Vann
    Simon Vann May 11, 2010
    Sorry forgot to as whaich CPU is installed and what Watts is the PSU?
  • Simon Vann
    When you power up does either the cpu or psu fans spin??
    President:
  • 2,351 Answers
Before trying anything, try another monitor. Or try you're monitor on another system. Swap the video cable with another. (This is a must try). The reason it’s a must try is because you hear the drive run, the fan's are running & the LED's are flashing. Once you are sure both are good than reset the bios.
(You typed, D845SVR as you're board). There is no such Intel MB. I think you meant to type, D845GVSR.
Unplug the power cord from the PC, open you’re case & touch any bare metal on the inside of the case surface before touching the mother board.
Please go to page 10 in you're manual. Make sure letter "D", the 12 V power connector is secure. Remove & re-seat it. Go to page 37 for instructions if you need a little help resetting the bios jumper. Move the jumper to pins 2 & 3 for 15 seconds. Than move back to default, pins 1 & 2. The link listed below is Intel's main web site for the MB D845SVR.
http://support.intel.com/support/motherboards/desktop/D845GVSR/
If you no longer have you're manual, you can download it at the link above. By resetting the bios, you are manually changing the bios to its default settings. Plug the power cord back in.
Try booting the system. You should get display. If you do not, than you're onboard (Integrated graphics), is most likely bad. A work around would be to add a PCI video card. The only other option left that I can think of is, it is possible that the CPU thermal grease between the CPU & heat-sink has dried. This will & can cause you're CPU to heat up. It may have overheated the CPU. PC repair is trial & error. Cleaning & replacing the thermal grease may allow you're system to function.
Here are a few PCI graphics cards you could try if you wish to buy.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=319&name=PCI-Video-Cards
Once a PCI video card has been added, the bios will use the PCI card without you needing to make a change in the bios.
Good Luck!
Mike
Posted on Jun 23, 2008
The mobo continuously beeps (ram not properly placed). so i took out the ram, reinstalled it and it worked. recently i wanted to change rams, so when i installed the new rams the mobo beeped again (similar...
I am not sure if you have tried this, but take one stick of ram put it in the first slot. Try to boot if it beeps or not, power down and move to the next slot with the same chip (we are assuming this is a good ram chip). Repeat for every slot on the computer. If you have 1 or 2 slots that beep and the rest do not; bad slot on the mother board. If all slots beep, try a different chip (bad ram??). If no slots beep, repeat steps with each individual ram chip (you could have just one or two bad and causing all the issues).
Hope this helps
Mar 26, 2012 | Abit NF-M2S Motherboard
Mobo fried? Beeps when startup but no video. I reseated ram and video card, with no luck. Both fans work and it sounds like it is booting. I tried older video card too but nothing. Thanks for any...
Try removing the display card and using the onboard VGA. Remove the BIOS/CMOS battery for about a minute and then reinstall it in the correct orientation. This will reset the BIOS/CMOS to it's default settings. You say it beeps once, this means that it is fine the mainboard is ok, it is not experiencing any problems. If it beeps in a continuous manner then it is the RAM that is causing the problems, I would say that the default settings may solve your troubles. Remember to enter the BIOS/CMOS when during boot up to reset the date and time by hitting the delete key. Also try entering the BIOS/CMOS even if you can't see any thing on screen, by doing this it may come up. let me know how it goes, I am here to help.
Thanking you
damnor01
Nov 09, 2010 | HP Compaq Presario SR5450F Desktop PC
Pavilion dv2125nr won't boot
it could be dead mobo, it's actually the most probable cause of your problem, but there is this thing i've encountered with HP several times already. i know it's a long shot, but i'd like you to try and boot the laptop up after you've removed the DVD-drive. if this works, it's the DVD-drive that's broken, if not, it'll be the mobo...
Jul 01, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
PC wont boot
It seems that one of your DIMM slots on your mobo has conked out, sorry pardner but might have to end up changing the entire mobo. Also try out your old RAM sticks on another PC for confirmation.....sodeep
Apr 05, 2009 | HP Pavilion m7640n PC Desktop
No display on my asus P4GE-MX mother board
Is there any beep from the motherboard? First thing that you need to check is the RAM. unplug the power cord and remove the RAM. Now, plug in the power cord and try switching the Comp and see if there is a any sound from Mobo. It should idealy warn you that there is no RAM with continous BEEP. If that happens, the Mobo is fine.... Grab a new RAM and try it out. The system should boot now. (If there was "No RAM warning beeps" when you switched on the system without RAM). There are many issues that may put down the Mobo but in most cases its the RAM that stops functioning... Try this and see if it helps. Please post your result here so that we can see if you need further assistance.
Feb 09, 2009 | ASUS P5PL2 Motherboard
Dell XPS 730 - Brand New - No display - Fan Loud
check if u r able to open the optical drive if its opening then power supply is gone bad or else get mobo an power supply replace
Dec 13, 2008 | Computers & Internet
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Intel Motherboard Logo
149 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
