Question about D-Link Wireless Cable/DSL 802.11G Router 54 Mbps [ DI-524 Wireless ] (114680)
Issues making a VPN connection with DL-524
Hey Experts, I have a rather strange issue with my Router. I am unable to make a VPN connection to work via the D-Link wireless router. However if I connect my laptop to the internet directly it works absolutely fine. I use an F5 Networks VPN client to make a connection. It says
a) Detecting proxy settings
b) Gives me an option to connect to the Gateway in my city.
c) Then says "Checking Registry"
d) Then just dies (timesout) after 2 mins
However, if I connect to the internet directly, this works absolutely fine!. Can anyone please help?
  • 128 Answers
SOURCE: Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address ( in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Posted on Feb 16, 2006
  • 6966 Answers
SOURCE: Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Posted on Aug 17, 2007
  • 6966 Answers
SOURCE: Router Configuration in "Wireless Client" Mode
Hi, If I understand you right, what you want to do is to make the DI-524 as a repeater, i.e. receive from the "external wireless access point" and re-broadcast to your "small home wireless LAN". Unfortunately, no. D-Link made it a point not to enable repeater mode in the DI-524 model (firmware has no support for wireless distribution service). Other than your old DWL-900AP+, one other model they have that can do this is the DWL-G710 but only in WiFi and not in the Ethernet port. On some other brands of similar feature models, the original manufacturer's firmware may be replaced with an open source firmware with more features enabled. An example is the LinkSys' WRT54G and the replacement firmwares by Sveasoft and another named DD-WRT. Hope this be of some information to you. Post back should you require additional information. Good luck and kind regards.
Posted on Sep 20, 2007
  • 33 Answers
SOURCE: how do i upgrade my firmware on my dlink dl-524?
Go to the following website to download the firmware update for the DL-524. This will save the firmware update to your harddrive:
1. Open the web browser
2. Type in the IP address of the DL-524 router.
3. Type admin in the user name field
4. Type the password you set on this device
5. Click on the Tools tab
6. Click the browse button and locate the firmware file you downloaded and saved to your hard drive.
7. Click the apply button to complete the firmware upgrade.
Posted on Mar 17, 2009
  • 390 Answers
SOURCE: vio and d-link wireless router dsl-2640u connection problem
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
Posted on Jun 24, 2009
I have to connect to work via a VPN, when I connect, the wireless becomes disconnected... after I disconnect from the VPN the wireless connection comes back. would the router cause this?
Check the Advanced tab of the N300's Firewall settings to see if VPN passthrough is enabled. If it's not, the firewall will cut off VPN communications.
You may also need to run the VPN Wizard on the N300.
Here's the manual:
Feb 15, 2015 | Belkin N300 Wireless N Router
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to upgrade firmware on Linksys router.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
I have a Belkin N1 wireless router connected to a broadband cable modem. I can connect to the internet via laptop & desktop with no issues. However when I try to connect to my work Sonicwall VPN it...
Firewall ports need to be opened. Log into router and turn on DMZ to your computer. Find your IP address on your machine 192.168.X.X and put that into DMZ settings or open up appropriate ports for VPN
Feb 11, 2010 | Belkin N1 Vision Wireless Router
I can access internet but cannot get in via cisco vpn(intermitent
Look at the number of users you have enabled in the router. If you only have 3 and you are using 4 computers, you could be getting the kind of behavior you are describing based on how many computers you have connected at the time.
Jun 18, 2009 | Belkin (F5D5231-4) Router
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address:
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
Dl-524 status blinking, cant connect to internet
- Updating the firmware of your router will do to fix the issue.
Mar 15, 2009 | D-Link DI-524 4 Port Wireless-G Router -...
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
96 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
