Question about Toshiba TZ50V51 50" Rear Projection Television
Image Shifted to the Right...
Not sure how, but while flipping channels, somehow a button was pressed and when I pressed the channel or volume button the screen shifted up and down and left and right. Also, there was the letter ''S" on the top right. I had to shut the TV off and on to remove the "S". Now the image is shifted to the right and I don't know what buttons to press to bring the image to the center of the screen.
  • 125 Answers
Did you go into the service mode, only a good technician should go into there
Posted on Aug 23, 2008
Reprogram channels on my Westinghouse tv model sk26h520s for a new location
Make sure that the source is set to TV. If you use the original remote, press the top button between the volume up/down and channel up/down buttons. If you use the buttons on the side of the TV, the Source button is next to the Channel Down button.
Next press Menu. (On the TV, it's the top button. On the remote, it's the top left button next to the arrow keys.) Now navigate down to Channels (use the Channel down on the TV) and press Enter on the remote (or Menu on the TV). Navigate down to Scan Channels and press Enter or Menu (as needed). Choose Antenna or Cable, depending on your source and press Enter again. (Note: the volume buttons on the TV are your left and right arrows in the OSD.) If you get a confirmation notice, select Yes and press Enter.
I hope this helps.
Dec 31, 2014 | Westinghouse Televison & Video
Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Oct 27, 2008 | Televison & Video
Toshiba 27A33. I can't find the manual channel button. Only the on/off button and volume buttons...
assumming your remote has a keypad with a bunch of numbers 1,2,3, etc those are the channels you press the combination of the channel number you want and press enter...sscrolling up and down thru the channels is probablymore what you want, and that should be located by a set of signs wghich has horizontal or vertical arrows right nex to each other...
Sep 09, 2014 | Toshiba 27A33 27" TV
How to put in video mode without remote
press the menu button and you should have a screen with Picture,channel set,eng/esp/fra, V-chip set up, caption (off).
With picture being highlighted press the volume up button, then press the channel down button until you see game mode, then press volume up for on and volume down for off...
Dec 29, 2011 | Symphonic ST420FF 20" TV
I have this mixwer for domestic use only, swithced it on last night and power is there, but no sound at all, from any channel.Could you please advise,
Make sure your audio source is playing.
Make sure your channel is not muted.
Make sure your channel is assigned to "main mix" (bottom button to right of main volume slider).
Make sure your main output slider has volume applied.
Make sure the cable you're plugging into your "main output" is being plugged into the 1/4" or xlr output receptacle that corresponds with the slider you provided volume to.
You should then put the outgoing cable into either an eq or an amp.
If you're going to an amp first, place the cable carrying the signal from the board into an "incoming" slot on the amp. Run a cable from the output of that channel of the amp to a speaker. Turn on the amp and fade the volume knobs up. That should give you power - provided your board, cables, amp and speaker are working properly.
If you're going to an EQ first, place the cable carrying the signal fromt he board into an "incoming" slot on the eq. Then run a cable from the output of the same channel on the eq to an incoming slot on your amp. Then run an outgoing cable from the same channel on the amp to a speaker. Flip your eq on, flip your amp on, fade up the volume on the amp, and make sure you don't have a gate closed on the eq (also make sure if you have a gain knob on the eq, that it's at least partially providing power). If your board, cables, eq, amp and speaker are working properly, you will have sound.
Nov 18, 2010 | Yamaha Mg8-2fx 8-Channel Mixer with...
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Can't change channel of a Motorola Visar Handie-Talkie FM Radio Model: H05RDD9AA4DN It seems that this radio operates in only one channel and I need to be able to chanmge channels. However everything else...
The Visar has a channel lock feature. If you hold down the two channel buttons at the same time, it will do one of two things depending on the settings. Either the channel will lock, or the channel numbers in the LCD will flip.
If you press the channel button and the "popples" "pop" (for lack of a better word) then the channel selection buttons re most likely OK. To fix it you just press both channel buttons at the same time for about 5 seconds. It will beep and you should be able to change the channels. If not, then it needs to be repaired.
Sep 17, 2009 | Motorola Radio Communications
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Wii hiikup to MitsubishiDigital TV
press the source button on ur tv remote if available. or flip channels till find right 1. and be sure that ur cables 4 the wii r inputed correctly.
Mar 29, 2008 | Nintendo Wii Console
Toshiba TZ50V51 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
