Question about Philips Magnavox DVD/VCR Dual Player
Player won't play any disks only says CANNOT LOAD DISK
Any disk I try in my Sony DVP-NS305 dvd player doesn't play, its any dvd and I tryed my disk cleaner and it doesn't play that either. It is driving me mad what do i do? I tried loading a few different types of CDs and DVDs. The documentation keeps pointing to a change in weather or humidity and let the thing dry up ..., which I'm trying now. I have Sony DAV DZ-120K , i am able to play CD and VCD but not DVD it's say;s reading reading ....and reading,
    Problem Solver:
  • 6 Answers
Http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Some Home dvd players may not have any adjustment abilities, but you would find such things not too far away from the lense, if they don't exist, get a new unit.
Posted on Nov 27, 2008
SOURCE:
I have a sony dvd player model dvp-ns305 i live in rhodes greece family send me films on formatted discs but my player says can not play this disc? can you give me advice or solution
If it plays other bought discs, then maybe your DVD player has been configured not to play pirated discs or the films weren't copied well.
Nov 25, 2010 | Sony DVP-NS305 DVD Player
My DVP-NS305 was playing all DVD's (multi-region) in colour but now only shows them in B&W. How do I change it back?
you can change colour setting in dvd setup to auto.after that colour come.when change setting power off dvd play then i will work fine.
Oct 17, 2010 | Sony DVP-NS305 DVD Player
My sony dvp-ns305 Dvd player will only play in Black and white.
first try to check the setting if its in ntsc or pal same with your television
Oct 09, 2010 | Sony DVP-NS305 DVD Player
Sony dvd/video combo dvd stuck inside
will it play the disc? try giving the door a little help when ejecting sounds like a slipping drive belt.farr64
Apr 29, 2009 | Sony DVP-NS305 DVD Player
DVD player stops the picture and re-winds to a previous track
I have a DVP-NS700,does same thing,but with copies.I just think they are more sensitive to bad discs,old/copies.I dont think there is anything actually wrong with it.
Jan 08, 2009 | Sony DVP-NS305 DVD Player
Is it multi region already?
not u would have to set the code to 0 all sum do sum dont usally need a unversal region free player out of box to do it
Feb 03, 2008 | Sony DVP-NS305 DVD Player
you can try this
http://www.llamma.com/xbox/Repairs/cleaning_your_dvd_drive.htm
its for xbox but all cdrom drives are simulate
Dec 05, 2007 | Sony DVP-NS575P DVD Player
Your system is in child lock mode. I had this exact problem this week. You need to put the system into standby mode and then press return, then enter then on/off and it will be unlocked.
Aug 28, 2007 | Sony DVP-NS305 DVD Player
change the way you connect the dvd player to your tv
Jun 22, 2007 | Sony DVP-NS305 DVD Player
Philips Magnavox DVD/VCR Dual Player Logo
171 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
