Question about Kirby Vacuums
My Kirby G6 light is not turning on when I start the machine. I took off the front piece and removed a lot of hair from the roller and interior. Since I did that, the belt keeps coming off (even though it is fairly new). Is that the reason the light won't turn on? Is there any advice you can give me before I take it in?
  • 357 Answers
The light indicates that the brushroll is spinning. If it isn't coming on, the power nozzle may have been reinstalled incorrectly. Take the nozzle off and then use my step-by-step guide to reinstall it. I expect that it will take care of the problem.
Hope this helps.... :0)
Posted on Jun 22, 2008
There may be dirt, hair, etc. lodged inside the end caps. Remove the brush roller and remove the end caps to check.
May 11, 2017 | Kirby Vacuums
My Kirby zip brush will not spin. I cannot take it apart, any hints?
No bearing inside only brass pivot, zip brush turbines get jammed because of hair getting trapped between the two blades, simply remove top holding plastic cap, it come into 4 pieces. lay out in order cut hair off spline and re assemble
Jul 13, 2016 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
The brush roller will not turn.The roller is about a year old and was working fine. The ends turn
If the roller ends turn (are not jammed by hair etc.), then there are tthree things to look at:
1. Is the belt that drives the roller in good shape?
2. Is the belt engaged on the motor shaft
3. Is the motor turning?
Dec 16, 2015 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
Was replacing the belt on my G6 Kirby and now can't get it reattached. Can't find my manual.
If it is any help, I usually put it on the motor shaft and then over the roller (which I have removed) and then replace the roller. I find this is easier on most models since you can then hold onto the roller (which is bigger) and have an easier time mounting the roller into the vacuum than mounting the belt on the motor shaft. Just make sure that you have the belt on correctly. The belt should only be touching the roller and the motor shaft, nothing in between. Hope this helps. Good luck!
Mar 13, 2010 | Kirby G6 Bagged Upright Vacuum
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
Jul 10, 2009 | Kirby Vacuums
Kirby G6 won't turn on.
If the brushead is removed,there is a safety switch which prevent the machine from operating if the brushead is removed or not installed correctly.Either this switch or the main power switch could be the culprit,as well as the cord.
Dec 13, 2008 | Kirby G6 Bagged Upright Vacuum
How do you install the belt on the kirby vacuum?
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Nov 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 attaching fluffer brush on shampooer
Sure can,
You have two choices,
1.) To use your shampoo attachment, you'll need the fluffer shield, To set up the attachment seperate the tray assembly (the part that holds the roller brush) from the nozzle assembly (the part that attaches to the machine). Now seperate the roller brush from the tray (easiest way is to pull the belt). Insert the roller brush into the fluffer shield (it only goes one way). Insert the fluffer shield with the roller brush installed into the nozzle assembly the plastic shield will be faced towards the front of the machine. Turn belt lifter to where the red arrows match and attach to the front of the machine. Turn belt lifter to where the green arrows match and you should be in business.
2.) Your using the floor buffing attachment it the easiest method just put on like the floor nozzle (thing you vacuum with).
Jul 21, 2008 | Kirby G6 Bagged Upright Vacuum
Loud noise with vibration
make sure there is nothing stuck in the roller brush. Or wrapped around the driveshaft (finger like thing sticking out of the front of the kirby when the powerhead is removed)
Jan 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
138 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
