Question about Motorola Mobility MOTORAZR maxx V6 Cellular Phone
Computor connection Since a hard drive failure & loss of programs I cannot connect my v6 to my computer. Any discs have been lost. Connection is with Telstra Aust. Can you assist?
  • 1 more comment
  • nandu8670 Jun 22, 2008
    Motorola MOTORAZR maxx V6, kindly sugggestion where to get system cd
  • Anonymous Jul 26, 2008
    motorola V6 need manual and installation CD can you help
  • s_h_r_a_y Nov 08, 2008
    i lost my cd...need to put in songs via computer connection,but it aint working
Lost disc to read photos from camera to computer
Posted on Oct 23, 2008
Hi I have a 2tb ext hard drive which was working fine on my soniq tv. Somehow the tv formatted/reformatted the hard drive and now none of the files work.. can't even read any of the file headings as they...
I have to ask, why would you connect a Computer hard drive to a television?
Remove the hard from the television and connect it to a computer. The hard drive hasn't been reformatted, because you can see the folders. If it reformatted it would be blank. With the hard drive in a hard drive enclosure and connected to a computer, you can try and read the data and find out why the filenames were altered and bring them back. I am guessing the file associations have been lost, or the file extension has been altered. There is also Undelete software you can use as well as diagnostic software.
Nov 12, 2017 | The Computers & Internet
Failure to query from radius server
You have lost the authenticity and ability to communicate with the server. Connection cannot be reestablished with out proper introduction via the communication protocol. This must be done within 24 hours of the loss of communication whereby failure to connect promptly will result in permanent loss of server use from that day forward.
Mar 10, 2013 | Computers & Internet
Hp compaq desktop black screen message disk boot failure insert system press enter
The words "disc boot failure" are terrifying for most computer users.
A disc boot failure notification generally means that your hard drive and operating system may be useless.
Fortunately, there are a variety of ways to troubleshoot your system in order to salvage your computer.
You may need to restart your computer a number of times before you manage to fix the error, so don't get discouraged.
A couple things to check first, make sure there's no floppy disc/cd in the drives, and if you are comfortable with computers, you can enter the boot setup of your BIOS, and check to see that your hard drive is listed as the primary boot device.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Or there is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Turn off your computer by pressing and holding the power button until the computer shuts down.
Locate the boot disc for your operating system (OS).
Turn on your computer and insert the CD into the proper drive before your monitor reaches the BIOS screen.
If the computer cannot read the CD, eject it and wipe the readable side of the disc with a clean cloth.
Restart your computer and re-insert the CD.
If this does not begin to load your operating system
Restart your computer and press the "DEL" key when you reach the BIOS screen.
This will bring you to BIOS settings.
Make sure that your hard drive is enabled to be read by BIOS. Restart your computer.
Access the command prompt by pressing the "F8" button at the appropriate moment.
Your monitor will display a notification at the bottom of the screen when you can access the system options with "F8." From the menu that appears, select the "Command Prompt" option.
Enter the text "fdisk /mbr". On the next line, enter "sys c:" and press "Enter."
This will initiate a system restore of corrupted discs.
If this does not clear the disc boot error problem.
Turn off your computer and remove the power supply.
Remove the side panel from your hard drive tower by hand or with a screwdriver.
Locate the hard drive of your computer in the top-front section of the hard drive tower when viewed from the side.
Using your fingertips, make sure all connections to and from your hard drive component are secure.
Locate the BIOS battery, which is a circular battery found on the motherboard.
Make sure that all connections to and from the BIOS battery are secure.
Check the connection of your computer's RAM to your motherboard.
hope this helps
Oct 14, 2012 | HP Compaq Presario SR1950NX PC Desktop
MY netbook is not booting. it shows on screen check cable connection! PXE-M0F:exiting intel PXE ROM no bootable device. To what is this problem related to and how can I solve it. thanks
Check the cable to your hard drive..... no bootable device, is indicative of hdd failure or an error in your Boot ROM. Since the system also indicated to check the cable, more than likely your system is completely unable to see your drive. This could be from loss of power to the hdd, or loss of connection between the hdd and the motherboard. (a third option would be failure of other components on your motherboard, which are far more money and hassle to fix than replace.) So.....
  1. using an appropriate screwdriver remove the screw the the disc icon next to it and any others necessary to remove your hdd.
  2. Remove the hdd completely and inspect for irregularities
  3. replace the drive and connect it firmly
  4. check the system menu for a connected device to verify that its really not being recognized
If your problem continues you wore than likely need a new hdd.
Mar 22, 2011 | Computers & Internet
Hard drive not showing on my computor, power connected, small light on the back of hard drive flashes when usb is connected to computor. Model 4910B
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 24, 2011 | Western Digital Computers & Internet
When I connect the camera to my computor to upload photos it says connection failed
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 15, 2011 | GE A1255 Digital Camera
I lost the disc that cazme with my camera and I since bought a new computor, I can't upload any pictures.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sep 03, 2010 | Vivitar ViviCam 3330 Digital Camera
Keep gettig disc read error when i turn the computer on. ran both recovery discs still wont work.
If you see disc error when booting, most likely it is either a hard drive failure or a loose interface connection between the hard drive and the motherboard.
Feb 13, 2010 | Toshiba Satellite X205-S9349 Notebook
Pentax optio S digital camera
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Nov 01, 2009 | Pentax Optio E10 Digital Camera
No Master drive 0 found
Hello!
this problem is made loss connection of the hard drive, Busted battery In the motherboard, Is this new harddrive? if yes then check the jumper setting, see label setting on the hard drive. It should be the hard drive is the master. no problem with your CD rom.
solution: replace the battery in the motherboard. and fix loss connection of the hard drive. or refix all the connection inside the system.
same issue occur, try to examine the hard drive maybe maybe you have to interchange the connection of the hard drive and the CD rom. if still , then try to not connect the CD rom only the hard drive.
Failure to resolve in this solution you may either change the cable of the hard drive or change the hard drive.
best regards, melnavz
ps. don't forget to rate me good rating.
Mar 08, 2008 | Dell Dimension™ 4600C PC Desktop
Motorola Mobility MOTORAZR maxx V6 Cellular Phone Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
