Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence I just had a "handy man" come and replace my Convergence ICs, and while he was working on the tv, there was a spark. But no smoke and the tv was not plugged in. Any suggestions? Also, I was hoping you could help with adjusting the colors from the inside panel that has the 6 knobs (RGB and 3 focus knobs) I have been trying and trying but still no reasonable picture. Keep getting green skies, or blue grass. Kinda sucks. I would greatly appreciate help if you could. Thanks.
  • 4 more comments
  • Robert Dressler Jun 23, 2008
    I just want to confirm. I found a place that has a manual for the tv for free online. You are talking about the knobs in the back right? So there is a way? I have already paid $550 for this tv. I am upset at that price right now. $300 for tv and $250 to fix convergence. When the spark happened he wasnt touching anything I was there. Weird! Anyway thanks for speedy help!
  • Robert Dressler Jun 24, 2008
    I am looking into it. I am sure it was just a owners. Do you have any idea of a good place to buy the service manual? Thanks or for even free?
    Sorry for being a pest. But I bought a service manual and I have having difficulty trying to find the right place. There are 1770 pages and can't find area to fix this problem. Any ideas? Thanks alot again!
  • Robert Dressler Jun 25, 2008
    I must have another type of service manual. There were 200 pages of stuff (not including convergence) and 1500+ pages of part numbers. Oh well. I will have to mess with this thing over and over. I have no choice. Thank you for your insight.
  • Robert Dressler Jun 26, 2008
    OK, one more problem so it seems. I was adjusting the RGB and figured out that I believe the main problem is the TINT and Sharpness do not change in the menu. There is absolutely no change in picture. Thats why there is no yellow and the sky can never be blue, i think. When the so called "professional" changed out the IC's, we saw a spark toward the blue side of the housing inside. Like toward the back right side if looking into the back of the tv. TV was not plugged in, could that still be static discharge? Could that do damage? If not, or if so is there are an area where that is controlled that I can check with a multimeter? A resistor, diode or something? Any ideas would be greatly appreciated. Thank you for your help.
    robert
  • Robert Dressler Jun 27, 2008
    thanks. will do
  • 3,037 Answers
The spark sounds like he accidentally touched a couple of wires together with opposite charges with power coming from the capacitors.
The settings are unique to the tv and require a service manual to set them. The default settings should have been recorded before attempting any change. Service manuals can be expensive and it may be worth just taking it to a reputable tv technician that can fix it for you. Let me know of any other questions that you may have.
good luck
Posted on Jun 23, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Jun 23, 2008
    yes, the knobs in the back. There are multiple types of manuals, you need the service manual, not the user manual. Which one did you find for free, most likely the user manual. No problem for the help, let me know if you have any other questions
  • Benjamin Patri
  • Benjamin Patri
    Benjamin Patri Jun 24, 2008
    Look at the index and go from there, try "convergence"
  • Benjamin Patri
    Benjamin Patri Jun 27, 2008
    Yes, if the tint controls aren't working, then that would display the problems that you are seeing. The tint puts the signal out of phase to change the colors. The service manual that you bought should be able to direct you to what you can do. You should try calling Phillips about this and see what exactly they recommend as they would know specifics better than I would I expect. Please let me know how this works out.
Sony rptv STK chip pins making spark and smoking
replace the two convergence ICs and also check the low ohm resistors and pico fuses. You can get the sony convergence repair kit for most sony models from www.tvrepairworld.com which has both ICs 4 of the resistors and all 8 pico fuses plus instructions for doing the repair.
Jun 24, 2012 | Sony Televison & Video
When adjusting the convergence, ended up with a concave screen, then it smoked. Is this a power supply, or worse? Is there any advice that you could give me on this...
Thats usually indicating the ICs have failed. Usually with that model its best to replace the board rather than try replacing the individual components as ther are several 3.9 ohm resistors that will need to be checked and possibly replaced along with both ICs. www.tvcircuitboards.com should have the replacement board for your model if you need one.
Jul 08, 2011 | Samsung HCL473W 47" Rear Projection...
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The 3 colors are not ligned up and the picture is out of focus. We tried the flash focus and that did not work. we tried the convergence but are unsure on how to use it.
Colors misaligned in rear projection tv due to failure of convergence output ICs and replacement of bad ICs will solve your problem, it needs soldering work in tv circuit board with proper tools, if you are handy with electronics stuff repair ad can replace parts in circuit board then let me know to provide you more info OR contact local tv repair shop to get tv fix.
Thanks.
Oct 31, 2010 | Sony KP-51WS500 51" Rear Projection...
Color is not blending. double vision of picture
This problem occurs due to convergence output ICs failure and replacement of two convergence output ICs will fix tv problem.
If you are handy and can replace chips in circuit board, let me know to provide you more technical info.
Thanks.
Aug 24, 2010 | Sony KP-53HS30 53" Rear Projection...
The colors are seperating making it look like 3d
This is symptom of convergence output chips failure in rear projection tv, replace convergence ouput ICs in tv to get it fixed.
If you are handy with electronics stuff repair and can solder parts in circuit board then check 2 big black ICs mounted with aluminum heat sink on D board of tv, replace them with same numbers and if you feel uncomfortable working with tv circuit boards, local tech will help you.
Thanks.
Mar 31, 2010 | Sony KP-51HW40 51" Rear Projection...
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Convergence chips
The convergence IC or in a sense ,amplifiers and the resistor are output resistors... if they are burning up the current going through them is spiking too high... TO me this is an indication that the "convegence yokes" are shorted. These are coils around the tubes that control convergence. I would suspect maybe that these are shorted to ground somehow. This is my first guess for this problem
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Mitsubishi WS-55807 "Bow-Tie" Problem
If your not a tech, its highly advisable to not even open the set because of the high voltage and x-ray radiation issues. Now if your a technician ,you gonna need to get a service manual, Look up the convergence circuit, Find the two or three convergence driver ics, find the b+ feed resistors to those ic, and order the exact replacement parts. if you dont replace all at once, and with exact replacements, you will be in the same boat a few months down the road. This is not a repair a handi-person should consider doing as even if you get the ics replaced, your gonna need to do some minor or could be major convergence alighnment and your gonna need a cross hatch generator to do this. This repair should cost ya about 300 to 400 bucks? Sorry man Good Luck
Jun 14, 2006 | Mitsubishi WS-55807 TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
