Vga drivers for compaq nx9010 laptop
Compaq nx9010 not detecting external 19" tft monitor, require drivers for the same.
  • suuim Aug 23, 2008
    Hi, i need the compaq nx 9010 vga driver as the monitor display does not cover the whole screen. Ineed the display to occupy the whole laptop screen pliz help.
    Champion:
  • 214 Answers
Hi, for the compaq driver try to download from here
Posted on Jun 22, 2008
Bad link
Posted on Aug 15, 2008
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
How can i get vga drivers for compaq nx9010
Here, check the link below and click on the download button:
http://drivers.softpedia.com/get/GRAPHICS-BOARD/OTHERS/HP-Compaq-nx9010-Video-Driver-80.shtml
This is the VGA driver for your Compaq NX9010.
Thank you and good luck!
Nov 15, 2010 | HP Compaq nx9010
The VGA driver is not found
If the VGA driver is missing you can download the from various internet sources man.. There are different website where in you can download the compatible VGA driver for your laptop Some of the top software site are like.. Brothersoft.com etc.. please do look for it and you can download as per your requirements. Regards Gizokieth
Oct 06, 2009 | HP Compaq Business Notebook NX9010
Vga drivers
drivers
select your OS then download the graphics driver
let me know how you get on
May 29, 2009 | HP Compaq Business nx9010 (DH938UABA) PC...
Monitor TFT 5015 now says "going to sleep
Make sure the laptop's external VGA port is turned on. There will be a function key somewhere on the keyboard (location varies by manufacturer and model) that controls the connector. If the connector has gotten turned off the external monitor will go to sleep because it's not getting any input.
Apr 09, 2009 | Compaq TFT5015 15" LCD Monitor
Black screen on compaq evo n610c
Couple of things to try:
Boot to safe mode by hitting F8 after you press start button. In safe mode try Last Known Configuration.
If that does not work then: reboot and log into safe mode with VGA. This will allow you to go into Device manager and see if you have a bad video driver. Try those two things and let me know what happens..
Mar 06, 2009 | Compaq Evo N610C Notebook
Vga drivers for hp laptop
It's not possible to connect your Monitor to the Laptop as the Pre Installed LCD Pannel of the Laptop reserves the Resources for Display Unit.
For more information on this, you may contact HP Customer care.
Goto www.sahajayoga.org to attain your Self Realization and find a Sahaja Yoga Center to goto.
Jun 22, 2008 | Computers & Internet
Computers & Internet Logo
4,819 people viewed this question
David Payne
David Payne
