Question about Miele 24 in. G665 Built-in Dishwasher
No Water entering machine at all.
Worked for 5 years,though shortly after renting house out they experienced problems.1st not cleaning and soap not dissolving.2nd water not draining and 3rd now no water entering at all.
  • pmasterson Jun 23, 2008
    Hey paul,guess what ..we have the same name..oh and the same email.My advice to myself would be to stop using this stupid site.Received 4 emails saying my problem has been answered but when i open email, all i see is my own question.Trying to steer me to the $$$$$ PREMIUM PLAN$$$$$
Hi, I was having the same problem but with a G572 (that's about 10 years old) though this might help you still as i believe they're all built fairly similarly.
My problem is I would start the cycle and I could hear the motor in the pump turning however no water would enter the machine.
Open the front door and look at the sprinkler on the base. Underneath it is a small tower (about 3cm high) and it has a cap on top of it. Take the cap off (mine just pulled off) and clear any grime that has built up inside of it. Now try to use the machine. (while I was clearing the grime I could actually hear something neutralise, as if there was air pressured up behind the grime).
I hope this works for you.
Posted on Jul 05, 2008
It may be that the tray underneath the machine is full of water and this appears to activate the anti flood device and shuts off the water supply. If you remove the panel under the door you should be able to check. There are 2 screws to the side and 2 to the top of the small panel. I am uncertain where the water came from on my machine but this appears to have solved my problem.
Posted on Jun 26, 2008
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Don't know how to use with shampoo
Best to not put shampoo in machine. Put traffic lane cleaner in sprayer with hot water, spray onto carpet after thorough vacuuming, allow cleaner to dwell 5 to 10 minutes and clean and rinse with fresh clean water in machine. For best results do NOT put shampoo in he machine even though it was designed for it. Most of the machines brought in for repairs are clogged with soap gunk. Carpets will be cleaner and stay clean longer because the soap has been rinsed out of carpet
Sep 26, 2013 | Vacuums
Frequent leaks through soap drawer during rinse cycle
Possible that the dispenser drawer is out of alignment or is the suspect. You can remove and check the mountings
click on : Dispenser
Jan 24, 2013 | Tecnik TKL9260 Front Load Washer
I have a GE Potscrubber dishwasher which is about 13 years old. I recently experienced a problem when I ran the dishwasher I had water leaking onto my floor. In addition, the cycle had not used all the...
The pump seal may be the problem. There are a number of places on the net where you can get step by steps and the the parts to replace the seal. Some recommend just getting a new motor pump housing which is 150. I just purchased the impeller assembly (it has all you need) and it cost $25 with shipping. Only thing is I did not realize I also had a leak in the solenoid stem valve. Let me know if you need the link I was talking about.
Dec 08, 2010 | GE Dishwashers
My Cabrio washer says F1...and flashes...what does this mean?
F1 error is a pressure sensor error on the machine control board,in short if the computer can not correctly sense the amount of water in or entering unit it will shut down. You are definitely not the first to have this issue..1st make sure you are using the right amount of HE soap. 2nd they tell you to make sure the clear pressure sensor hose from the tub to the computer is not cloged or leaking air. 3rd you will have to replace the machine control board,and you dont want one thats been sitting on the shelf for a couple of years as the have been going through constant upgrades (problems) Good luck
Sep 17, 2010 | Whirlpool Washing Machines
No water goes into dishwasher. Dishwasher has only been used 2times. Came new with house 3.6 years ago. Pulled front panel off...everything appears to be connected motor fan runs.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
Jan 04, 2010 | GE Nautilus 24" Built-in Dishwasher
When the cycle is finished the dishes arent washed, in particular the ones on the top rack. Ive removed the arm that carries the water to the top sprinkler to see if its blocked and it seems to be OK.The...
Being from the US, I have not worked with this LG dishwasher, not any down under.
But the first thing to do is use only a name brand dishwasher detergent powder. Don't use gels or tablets, ever. Many cleaning problems are resolved by avoiding the ultra cheap generic detergent.
If problems continue, confirm that the heating element is still working. Dishwashers need heated water to activate the soap.
If problems continue, my next move would be to remove the gear beneath the lower spray arm and clean everything and remove debris that could be blocking the water flow.
Good Luck!
Apr 08, 2009 | Dishwashers
Fabric conditioner not leaving compartment properly on miele washer
hiya
sounds like you have a problem with your cold inlet valve or maybe a blockage in the soap dispenser housing. remove the soap drawer and just give the top of the housing a quick clean. if the problem persists you may have to call a miele engineer out as the machines usually come with a 10 year warranty (check first though)
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 01, 2008 | Miele Washing Machines
LG washer (WM0532HW) whites turning dingy grey
I too have a front load washer. The problem is that it's not washing off all the soap suds. Try this. After a complete cycle, soak the clean clothes in a container w/ water and you'll see there's still soap suds coming out of the clothes. I tried running it several wash cycles and there was still soap left on the clothes. I think, it's mfg defect. We should all complain to the maker of the machines.
Jul 25, 2008 | Washing Machines
Hotpoint Aquarius WD640 Progressive problems now causing flooding
Normally if it leaks then the one way valve in the back of the machine is clogged, you remove the back, undo the jubilee clips on the 3" black hose & clean the ball.
May 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Miele 24 in. G665 Built-in Dishwasher Logo
505 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
