Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Spin cycle bad noise
At the end of spin cycle there is a bad sound -to me it sounds like when a person pulls out with a manual transmission and the clutch isn't released right- sort of like a skidding sound as it stops or like i say chatter
  • 57 Answers
Your trans breaks are sticking they need to be cleaned or replaced
Posted on Jun 24, 2008
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
My Asko 10504 has started making what sounds like a metal on metal grinding sound when it spins. It's as if the whole drum assembly is moving more than it should and coming into contact with something,...
COULD BE THE TRANSMISSION SPRING OR TRANSMISSION BEARINGS. EVEN UR TUB BEARINGS IN THE TUB, A BAD MOTOR COUPLER HOWEVER U WOULD NOT GET ANY SPIN OR AGITATION IF THE COUPLER WAS BAD. BAD BREAKING SYSTEM WOULD NORMALLY MAKE NOISE BUT WHAT U WOULD GET THEN IS A COMBINED SPIN AND AGITATION DURING SPIN CYCLE,
Mar 23, 2015 | Asko Washing Machines
Frozen with spin and end lights lit whilst making a humming noise
sounds like motoer or transmission is sticking. could be a problem with control switch.
Jul 13, 2012 | Washing Machines
Simpson encore 605
Sounds like a motor transmission problem.190.00 parts and labor is not a bad price.
Check if there is a warranty with the new parts the service person is installing.
Oct 27, 2011 | Washing Machines
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Agitator wil not move makes a growling sound but all spin cycles still work
Either the transmission is bad, or more likely the agitator dogs are broken. If you pull the top pieces from the agitator you can see the agitator dogs and tell if they are intact or broken. If they are good, the transmission might be bad. The only other thing will depend on if the machine goes through the wash cycle to the rinse and spin without ever agitating, or if you have to manually move it. If you have to manually move it, your timer is probably bad.
Sep 06, 2009 | Washing Machines
Loud steady noise during rapid spin cycle
sounds like the bearings are on the way out bud they can be changed but its not easy
Aug 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Washer model #PAV2360AWW
It is not the trany it sounds like you need to get your tub seal and bearing kit installed.The trany is fine it can get costly if you get a person who does not know how to fix properly good luck:)
May 04, 2009 | Maytag PAV2300 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
