Loss of power on LG WF-T652A
Machine all loaded and operating suddenly lost all power,
checked fuses etc all are fine.
does this machine have a fuse built into it?
I have the same problem as you. Machine was stopping intermittently in wash cycles - usually near spin/drain and sometimes just wouldn't turn on. Now it won't turn on at all...
Posted on Jan 17, 2010
Lg washing machine model wf t652a fuzzy logic wont spin
check pump is not blocked or faulty if good its probably the brake motor
Oct 25, 2017 | LG Washing Machines
LG WF-T652A I have a leak when the machine is on. I have checked both the outlet pipe and the pump , neither are leaking or show signs of water. Is there an overflow from the bowl which may be the s
when the cover is off turn the machine on and trace the leak if you can it could be from a faulty valve. also see where the leak is on the ground so you can get a idea where the leak is.
Jan 09, 2015 | LG Washing Machines
LG wf-t652a displays an error "PE" & dinging when turned on. Any suggestions.
Pressure sensor error. Check also the pressure hose. The pressure sensor stops the water at a set level depending on the cycle you choose.
Jul 16, 2014 | Washing Machines
Warning alarm
i am using an LG washing machine model WF-N6861DN.its giving a warning alarm after 3-5 seconds of operation
Jun 04, 2009 | LG WFT1071TP Top Load Washer
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Sep 16, 2008 | LG WFT1071TP Top Load Washer
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Dec 19, 2006 | LG WFT1071TP Top Load Washer
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
