Question about HP OfficeJet V40 All-In-One InkJet Printer
HP officejet v40
When I turn my printer on it says self-test, then it starts trying to move the ink carriage and starts clicking horribly. then says clear carriage jam and restart, there's nothing in the way of it, so what could be wrong?
  • Increase Aug 02, 2008
    When I turn my printer on it says self-test, then it says "remove and checke color/black cartridge. I updated print drivers, it finally printed two test pages and in the middle of printing the second page, it just stopped printing. I cannot print anything at all now.
    I uninstalled printer, and reinstalled printer as well. Can you help me?
  • HP Master
  • 2,794 Answers
If its clicking something is jamming the carriage or the timing could be off.
It should be looked at by a technician to get it adjusted properly.
Posted on Jun 22, 2008
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Jun 10, 2011 | HP Officejet 5610 All-In-One InkJet...
I have a hp printer officejet J5780 All imn one.
I have found this model has a bad buildup of black ink in the right carriage bay chamber. With the printer on, open the carriage access lid and pull the power cord before the cartridge carriage can move all the way to the right side. Then gently push back the cartridge holder on the right if it's in your view, so you can see if there is a collection of black ink. The tri-color cartridge has a preventive bracket that doesn't seem to build as much as the black one. Anyway, once you've cleared any dripped ink cones or globs, plug the printer back in, turn it on, and if you get the Carriage Jam error one more time, press OK, and it should work well if that was the block on the carriage movement. I hope this helps you to get printing again.
May 04, 2010 | HP Officejet J5780 All-In-One InkJet...
Carriage jam
Step 1: Move the carriage to the center manually if necessary If the carriage is stuck on the right or left side of the product, follow these steps to move the carriage to the center of the product.
Step 2: Check for a broken carriage chute
The carriage chute is the side wall of the carriage that holds a curved metal piece (the x-bias spring). A broken carriage chute might cause the carriage jam condition.
Step 3: Turn the product off and on again
Step 4: Clear any paper jam.
Step 5: Make sure that the control panel faceplate is correctly installed
Step 6: Plug the All-in-One directly into a wall outlet
Step 7: Perform a partial reset
Step 8: Print a self-test page
Step 9: Service the product. Now this model is outdated as per HP website.
Aug 23, 2009 | HP Officejet 7210 All-In-One InkJet...
How do i access the print cartidges on my hp officejet v40?
Below is a link to the Setup Guide. Click on it and see steps 12 and 13.
V40 Setup Guide
Dec 07, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Hp officejet v40 printer
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
Good Luck
Sep 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Ink carriage does not move...
the carriage is hooked when it tried to move that why the noise you try to set the carriage so as to balance and free it self then it will move ive had similary and i resolved it that way
Jan 21, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Hp officejet r40 cartridge carriage blocked
Not sure about r40's, but look here about the leaking ink solution for G85's and DJ900's: http://www.fixyourownprinter.com/forums/inkjet/22399
There is a guy named BERT who is a master a fixing HP units, and his email can be found in the above mentioned forum note.
Dec 31, 2007 | HP OfficeJet r40 InkJet Printer
V40 not printing black, only pink
Print a test report
  1. On the front panel of the product, press Menu (or Setup) .
  2. Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK .
  3. Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK .
check and see if the colors are ok.
If not see this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&cc=us&lc=en&dlc=en&product=60630&dlc=en&lang=en
Oct 10, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
Hp officejet v40
ink carriages are full but still not printing?helpp
Sep 30, 2007 | HP OfficeJet k60xi InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
113 people viewed this question
Ben Johnson
