Question about Gateway GT5228 PC Desktop
Network card driver
I have a Gateway GT5228...I just had to do a fresh install of the OS and, using the original boot disc, it seems my integrated network unit didn't recieve the drivers.....im confused, and can't connect to the internet on that computer now. It's not the ISP, i've checked that.
    Novelist:
  • 119 Answers
Try to go to this link and download and install all drivers that applies. install the chipset first then you may install the rest of your device drivers:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1014951R
Posted on Jun 22, 2008
Reinstall windows 7
Most laptops have what is known as a recovery partition on the hard drive. This partition has a mirrored image of the factory-installed original configuration. Check your users manual to see to how access this partition. If you can boot Windows, some manufacturers have set up the ability to do the recovery from the OS. If the OS is so badly messed up that your can't boot to it, there is usually a hotkey combination that you press at bootup to get to the recovery routine. You may also have received or made a set of recovery discs when you purchased the laptop. These can also be used to return the unit to factory fresh condition. If you have neither, you will need to use a Windows 7 Installation Disc. This will install the OS, but will in most cases, not have all the drivers you will need to activate all the installed peripherals such as network NIC, sound, bluetooth, etc. These drivers can be found and downloaded from the manufacturer website. You need to know the Model number of the unit and the OS you are trying to download drivers for.
Mar 05, 2015 | Computers & Internet
Sd card wont show up on my gateway gt5228
You are missing the drivers for the card reader. They usually come with the chipset driver installation. I looked up your driver downloads on gateway support and it says there is also a driver in the "others" section caller "motherboard driver"
So, what you want to do is go to there site at the link below and download the "chipset" driver and the "motherboard" driver and install them. that should fix your problem.
Drivers link:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2895
Jun 26, 2012 | Gateway GT5228 PC Desktop
M520 video drivers not installing
You can download the video and device drivers for your model Gatewaylaptop from this WEB site. Make sure you select your model laptop and thecorrect Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Nov 10, 2011 | Gateway M520 P4-2.8 GHZ 15.4 (1008316) PC...
Gateway ma7 will not boot up. Tried to restore it with a disc but then it says the hard drive is non existant-would there be another issue?
is your restore disc the MS OS disc?are you trying to fresh install OS? if so then you need a restore/ OS disc with SATA drivers in it...then it will 'see/recognise' your HDD
Jun 29, 2010 | Computers & Internet
My Ethernet card isn't showing up in my network adapters section of my devices. I also don't know what the Ethernet card's model is. Is there any way to get it working?
Is it an integrated card (the ethernet connection would be located on the back around the middle along with the USB connections that are built-in to the motherboard. If it is integrated, make sure it is enabled in the BIOS. Since it is not showing up in the Device Manager, it is disabled through the BIOS or it is not functioning. If it is an add-in card, try removing the card and reseating. If you still do not get an entry (possibly Unknown) in the device manager, it is time to replace the card.
Feb 24, 2010 | Gateway 5310 (1008368) PC Desktop
Gateway GT5228 - USB Ports & All-In-One Card Reader don't work...
what service pack froom MS have you downloaded and installed? Sounds like the SM BUS DRIVER ARE MISSING. Install SP3 AND LET ME KNOW.
Feb 16, 2010 | Gateway GT5228 PC Desktop
Video is out, on GT5228 Tried new monitor, do not seem to have the right type of video card to install a secondary card assume that it is the motherboard. How do I verify
if video card does have a hdmi-output, try this one plus fitting monitor.
no sign?
to blindtest the mainboard, remove the RAMs,
if it gives bleeping sound, it is still functioning.
when booting up, listen if the harddisk or cd-rom drive still makes any sound.
if it is the video card, then computer might hang up here while booting, video device is always checked first, so if it gets stuck here, you won't be able to tell until you've doublechecked with another (AGP?)video-card, iam afraid...
Aug 03, 2009 | Gateway GT5228 PC Desktop
How can I find out what kind of network card is in my GT5228?
Integrated 10/100 Network.
Unless you put a card in yourself, that's what came with your computer.
Jul 15, 2009 | Gateway GT5228 PC Desktop
Boot into safe mode and see if you can either roll back the driver restore the computer to the date right before you downloaded it.  the link is for directions on how to boot into safe mode.   Another option , if you have on board graphisc alos is to hook up the monitor to the onboard  turn it on in BIOS and change the driver for the card using the onther graphics.
http://www.pchell.com/support/safemode.shtml
Jan 28, 2009 | Gateway GT5228 PC Desktop
Graphics card doesn't Install
sp3 always messing stuff up uninstall sp3 than install ur card
Nov 29, 2008 | Gateway GT5228 PC Desktop
Gateway GT5228 PC Desktop Logo
353 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
