Question about Teac Audio Players & Recorders
I need help to replace the belt in my Teac C-3X
I did not mean to say anything negitive about you!
I need a little more step by step way to get to the flywheel, or the proper order to remove everything that is in the way to install the new belt. The flywheel is tucked into a place that is not easy to access. So, I guess I'm on my own....and I'll just start removing parts until there is nothing left to remove. I think Teac built the deck around the belt with no hopes of anyone ever changing it.
Posted on Jun 23, 2008
  • 1,512 Answers
Hi rjwolfe
You can get a complete set of drive belts from here
There is a great instructional guide by the same guy here.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 22, 2008
  • Graeme Ross
    Graeme Ross Jun 22, 2008
    Just wondering, as you gave me a somewhat negative rating in a Thanks for trying for my advice; were you looking for someone to do the job for you? I can locate someone in your area if you like For my self I have overhauled thousands of tape decks over the years, changing belts is not that hard a job when you have done a few. Your first one may take a little longer, but you have to just get in and do it. The service manual does not give you instruction on you how to do it, the learning part comes from doing it for yourself.
  • Graeme Ross
    Graeme Ross Jun 24, 2008
    The entire transpoer will detach from the transport. Sometimes you have to take the front panel off the get access to the screws that secure it in place. OR they are in the four corners of the transport with sometimes additional screws from top and bottom. Dont go crazy, remove only the screws that are required. Release the spring/actuator for the record play switch and you are in.
    How bout upgrading me to FixYa,and I am, as I said,happy to help you. OR, you could go for a live chat, and accept me for your chat.
    I can do it from here better though really.
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
Teac a103 cassette deck. I want to know how much of this thing do I have to dismantle to replace the belts?? the online manuals ****!
It is not all that hard. You need to take the transport out of the chassis and then remove the screws required to get the motor mount and thrust plate off of the rear area of the flywheel. I have done them many times at Teac in the Chicago Factory Service. You need to get the right belt first. There may be more than one belt to replace in the unit such as one in the front near the counter. I can fix it but it might not be as cheap as you might think. I have been servicing Teac decks for 40 years so far.
Teac Tascam Repairs Skywave Tape Deck Repair Bensenville IL
Jan 19, 2014 | Audio Players & Recorders
Getting belts for TEAC W-890R. I'm currently sitting here a home with a DEAD TEAC A-350 Cassette Deck -- DEAD because I was told you can get belts for it (I have since found out that is is NOT true and...
That is the state of conditions at Teac and they don't care about tape customer anymore. If you need belts for any unit it is simple to find the belt kit at Marrs Communications. They do not have he cheapest prices bu the you don't know what size you need and Fred took time to find his out. If you want to do it the other way you download a copy of the PRB cross reference manual and look up the belt type that goes into your deck. The you go to Ken's Electronics and order the belts online. This does not come with instruction of how to put them in. In my many years as a Technician working on all kinds of tape decks I have never seen an instruction to put belts in a machine- it is assumed that if you can not figure this out that you probably do not belong in the machine. In cases where belts are not in place sometimes the parts layout diagram can help you determine how they go in.
I am an ex Teac Lead Technician from Chicago.
Aug 25, 2013 | Teac W-865R Single Cassette Deck
How to replace the belts in a Teac A300 cassette deck
The mechanism needs to be taken apart sufficient to get to the flywheel and capstan motor- this usually entails taking the metal motor bracket off the back. It is not that difficult once you have done one. I may have replaced 50 to 100 of them at Teac in Chicago. Also oil the capstan bearing when changing a belt.
Aug 08, 2013 | Teac Audio Players & Recorders
I have a Teac LP200 and the turntable will no longer turn when I lift and move the arm over. Is there a belt to replace? How does one access it?
your unit has "The efficient belt-drive system provides accurate play and control" and normally the belt lasts for long time ..i.e at least 5 years..
If you sure that it is belt ,you need to take the turntable disc (should be a security pin in the middle ) than you can access underneath of disc or some models needs to access from bottom of the turntable ,inside the receiver..
just in case ,if you need detailed user manual in pdf format pls visit he URL below..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
User Guide for Teac LP-U200 View Table Of Contents»
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jun 25, 2011 | Teac LPU200 Turntable
I have a Teac A-1500 reel to reel tape recorder and need a drive belt for the capstan, Can you help me?
Contact: pjheiland@hughes.net He can supply drive belts for Teac reel to reel recorders and other manufacturers units.
Mar 31, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
I NEED A REPLACEMENT TURNTABLE BELT FOR TEAC JC 50 STEREO
Just measure the diameter of the old one and it's width. Then put these measurements (in mm please) into Google and and the words "TURNTABLE BELT " and you should find one. Belts are not maker specific.
Jun 24, 2010 | Teac Audio Players & Recorders
Teac X-1000r broken drive belt
Gidday Chino
You can get a FRESH belt kit from here. Cost you $10 plus some post. There is a new pinch roller listed against this old girl also could be worth replacing at the same time when you service the deck.
regards
robotek
Aug 05, 2008 | Audio Players & Recorders
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
47 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
