Does my Sylvania Liquid TV have a built in digital tuner? It was manufactured in 2006.
My TV does not have a built in digital tuner, will have to buy a converter box.
Posted on Jun 24, 2008
RCA Guideplus gold gemstar analog or digital
Most of the RCA GuidePlus Gold gemstar TVs worked with analog TV signals (NTSC) only. The Guide+ information was only broadcast in NTSC signals and is no longer being provided. If you can check the date of manufacture of the TV, you can use the size to check if it had an ATSC tuner added if it was made for the US market. 37"+ TVs had to have a digital tuner in second half of 2005. 25" TVs needed to have the ATSC tuner after March, 2006. The next year all TVs had to have a digital tuner.
I hope this helps. Please add a comment with the model number of the TV, if you would like me to confirm the tuner information on your set.
(The RCA F31317 TV with Guide+ was manufactured in 2000 and thus only has a NTSC tuner.)
Dec 26, 2015 | RCA Televison & Video
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
Does a hitachi 42 inch need a converter box to be able to watch regular tv
Which model do you have? The ATSC tuners were required in 42" TVs starting in the middle of 2005. Some Hitachi 42" TVs built before that date have an ATSC tuner but other models do not. The ones that didn't were usually called HD-ready TVs. For those models, you need a set-top box to receive OTA signals (except for some low power stations that continue to broadcast an analog signal).
If you provide your model number, I'll try to confirm the tuner information. If you look at the model information plaque on the back of the TV, you will see some information about when the unit was manufactured. If it was built in 2006 or later, you can be sure that the unit has a digital tuner.
I hope this helps.
Nov 23, 2014 | Televison & Video
Want to Know if my TV is a DTV
it most probably is DTV ready, try googeling some on the subject, but since its a LCD tv from 2006 its most likely to made with a digital tuner. Note : if you have cable or satelite ( dish networks, Direct Tv and so on ) you are allready watching digital TV and do not need a converter box.
Mar 05, 2009 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
About Sylvania TV
Hi malumbender,
Your tv dosn't have a digital tuner, in order to recieve OTA (over the air) digital signals you will need a Digital Converter Box.
Here is a link to a government website for coupons for the box. The coupons are for $40 off the purchase price of the box. There is a waiting list but they will come available as other coupons expire.
https://www.dtv2009.gov/
here is another site for antenna and channel line up.
http://www.antennaweb.org/aw/welcome.aspx
I hope this helps and please rate this solution, please keep in mind that a "Thanks For Trying" rating is negative.
Lone99star
Jan 26, 2009 | Sylvania 6615LFP 15 in. EDTV-Ready LCD...
Do I have digital tuner?
No, this set does not have a digital tuner. The TV must be an HDTV in order to have a digital tuner built in.
Dec 31, 2008 | Sylvania 6720FDF
Digital TV??
Your set does not have the correct tuner in it. However, the broadcast change only effects those that use an external antenna for reception. If you are using cable, satelite or any other service for TV, you do not need the converter.
Dan
Jul 15, 2008 | Televison & Video
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
SYLVANIA 6620LG TV - DTV??
The ;quick answer is YES, you will need a converter box to receive digital broadcasts. This set has only an analog tuner built-in. That is why it is HDTV "ready" (ready for you to add a tuner).
As for HDTV vs EDTV it is a matter of resolution. Your set is capable of EDTV resolution, which is better than SDTV (standard definition TV) but not quite as good as HDTV. With a digital tuner you will be able to view all digital programming, even HD, and it will look excellent, though not quite as sharp as a set with higher definition.
Feb 14, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
