Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Whats wrong with my flashdrive?
My SanDisk Cruzer Micro 2.0 GB flash drive has this "ReadyBoost" or "SFCACHE File" on it that literally taking up almost all my flashdrive's memory. I go to delete and it starts to delete but than it says it needs permission to delete this file when I already have given it. I dont know whats wrong. Can anyone help? Thanks.
  • matt91 Jun 23, 2008
    I have Windows Vista and i am the administrator.
    Sergeant:
  • 291 Answers
Are you on Win_xp? If so, are you the administrator? If not Win_xp won't let you delete ANYTHING!
Posted on Jun 22, 2008
I have deleted some folders from the drive, cruzer micro 8gb, and now I have a file called "ReadyBoost.sfcache" sitting in the drive taking up 4gb in space that I cannot delete or remove.
click start click to open on my computer you should see your Usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
click on your usb drive select format
or you might have to open up the ReadyBoos.sfcache tfile and delete the files individually
also right click on each file select properties to make sure you have full control
if you need more help with this post a reply
hope this helps you
Sep 14, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Error message states that there is not enough room
One possibility: you have too many files in the directory. USB flash drives are usually formatted in FAT32 and thus stuck with the limits of the standard. Try moving some of your files into folders.
Second check for a encrypted partition locking part of the disc. If ReadyBoost capable a section of the memory set aside to do ReadyBoost for Windows Vista or Win7 (you'll need to release the ReadyBoost on the computer that dedicated the space).
I hope this helps.
May 13, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I just purchased an 8 GB flash drive sandisk and when I went to download my outlook, which is a little ver 4 gb, it is telling my I don't have enough space on the flash drive. I literally just opened it....
Try doing a full format of the drive. (Right-click on drive => Click format).
If you have the option format using the NTFS file system (default in vista/windows 7) and make sure to uncheck "Quick Format". Remember to back-up your data on the drive beforehand.
If this doesn't solve your problem the flashdrive itself may be faulty. Return it and have it replaced.
Hope this helps,
-LL
Feb 24, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Information on downloading file from a micro cruzer flash drive
if it is a regular folder just right click and copy and past it to a desktop my documents anywhere.if it is a program folder for u3 then it will only work for the flashstick.programs for u3 can only work on a flashdrive.please explain a little more what the downloaded file is.and what you want to do.if you got any questions please email me at gamecrazy944@yahoo.com
Aug 03, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 2 GB Cruzer
hai,
it seems ur flash drive is infected with some virus
scan the drive with an updated virus scaner.
if this does not succeded, copy ur data to the HDD and go for a full format.
good luck
Please don't forget to rate or accept the solution
Jun 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer micro flashdrive - not working on vista
you'll need to go to the sandisk site, and get a vista driver set..
Mar 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
166 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
