Hello
OK, now, the only components in your computer which actually rotates which can explain the the sound you are hearing is either the CPU fan or the CD/DVD rom or the Hard Drive.
You can test if it is the CD/DVD rom by opening your CD/DVD rom while starting the computer up. If the sound persists, it is most probably your CPU fan.
The reason for your CPU fan to rotate at high speeds is most likely the result of the CPU itself not getting the sufficient cooling, hence the fan needs to rotate faster.
I would suggest that you have a look into the matter if it is your CPU fan, because this might cause your CPU to become faulty when it overheats. You can open up the unit and use some compressed air to get rid of all the unwanted dust particles on the CPU heat sink and fan.
Fell free to let me know if you need any further assistance.
Kind regards
Andrea
Downloads the bios file from this site.. Extract into a formatted usb .. Plug the charger ... and plug the usb .. keep pressing FN+ESC button then turn on the laptop u can see light is blinking .when light stop blinking release buttons wait for 5 min ..System will restart.. And u can see display.. Thanks
http://macles.blogspot.com/p/acer-aspire-one-bios.htm
