Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia 232T and S-Video
I hooked up my s-video cable from my computer to my tv and the tv says "No Signal". I'm trying to watch videos that on my tv that are on my laptop. So can someone tell me what I need to do. Once I get a signal how do I tell my computer or the tv to share the information. Help appreciated. Meshell
I did as suggested and still it doesn't appear on the t.v. Perhaps I'm doing something wrong. Can you walk me through it?
Thanks
Posted on Jun 25, 2008
    Brigadier General:
  • 6,966 Answers
You would need to press Fn + F? keys on your laptop to enable the S-Video output and therefore viewable on the Olevia 232T. The F? key would be dependent on the make & model of the laptop. Normally, it is one of the F keys and would often have a small monitor icon below the number.
In some instances, it maybe necessary to lower the Screen Resolution of the laptop computer's display (and probably the Screen Refresh Rate too) for the Olevia 232T to be able to display it. Additionally, the message "No Signal" does not only refer to the absence of a signal but more correctly due to the absence of a usable signal. At this point, the output of the computer through the S-video may be there but would be too high for the TV. To my knowledge, the Olevia 232T can display maximum screen resolution of 1366 x 768 but you may want to try first 1280x720 or even lower. You of course can eventually increase as may be allowable.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 22, 2008
My olevia tv shows a no signal on screen, what could it be?
try this Audio Out of your Cable box colored RED and WHITE is connected to your TV's Audio In RED and WHITE. And connect the VIDEO out of your cable box YELLOW to your TV's VIDEO IN function c_getProfessional_AskGet_refreshPicture() { var imm = $("getProfessional_ask_fromprchat"); var val = false; if(imm) { val = $("getProfessional_ask_fromprchat").checked; } var pOn = $("c_AskGet_checkBoxOn"); var pOff = $("c_AskGet_checkBoxOff"); if(!pOn || !pOff) return; if (val) { pOn.style.display = ""; pOff.style.display = "none"; } else { pOff.style.display = ""; pOn.style.display = "none"; } } function c_getProfessional_AskGet_toggleImmediate() { var oImmediate = $("getProfessional_ask_fromprchat"); if(!oImmediate) return; var val = oImmediate.checked; oImmediate.checked = !val; c_getProfessional_AskGet_refreshPicture(); } c_getProfessional_AskGet_refreshPicture();
Mar 26, 2010 | Olevia 227-S11 27 in. LCD TV
How do I hook up cable on my olevia tv
try this,
Oct 11, 2009 | Olevia LT32HVM 32 in. LCD Television
My TV says NO SIGNAL on tuner...
yes, you may be lucky to just to burnt one of the source/input mode try switching them.
for example use a video cable instead a coax if you still dont get a signal that means the picture uotput board is damage by the storm.
Aug 15, 2009 | Olevia 227-S11 27 in. LCD TV
HELP Can't find manual or remote for 232T Olevia
This manual is for the 232V but its the same functions as the 232T
http://www.olevia.com/ecms.ashx/36cc6c74-60f9-4caf-b6f7-d05024d13e44/Products/232V_English_User_Manual.pdf
Also Olevia made a universal / Learning remote that will work with olevia and also with other device.. the company that is currently selling them are called Amergence Technology ( ph. 866-965-3842 )
Jul 30, 2009 | Syntax Televison & Video
Are you sure you actually have an S-video input on that TV. The specifications I find don't show one. (http://www.olevia.com/en-us/Products/2Series/232TLCDHDTV.aspx#2
If you do, you might have to select video on your remote in order to see the input. If you have the instructions for the tv, look at those.
Otherwise, try downloading your users guide for the laptop and see where it points you
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Mar 28, 2009 | Dell Latitude D600 Notebook
I hooked my olevia tv up to cable tuner box but cannot get a pict
Try switching throught the various video inputs on your tv until you get a picture.
Jan 30, 2009 | Olevia LT32HVM 32 in. LCD Television
No video display,
UUUHH HHHH DUH!!ITS NOT MENT 4 PS2!!!
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Connecting vcr to tv
Find Video & Audio Out pins at back of Combo player. This is output signal which will be connected at Video & Audio Input at front of TV. Watch out video pin will go to video input. Now select AV input of TV by remote. Usually its AV-4.
Have fun, or need more info, let me know the out comes.
Oct 22, 2008 | RCA VR546 S-VHS VCR
Olevia 232t remote code
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control both the Satellite Receiver and the Olevia TV (Everything on the Olevia except the A-B-C-D Guide buttons). The Remote Control User Guide lists the control codes, four for the Olevia. The codes are:
Satellite Receiver: 00392
Olevia 235-T12: 11610 (last of the four codes listed for Olevia)
Enjoy!
Nick from Ft Myers
Dec 21, 2007 | Directed 434MHZ Remote Control
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Olevia LT37HVS 37 in. LCD HDTV Logo
219 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
