Question about Pentax Cameras
Every sd card that i put in the camera it is saying the card is lock. i have tried and even buy a new caed but still saying that the card is lock how can i fix this problem thanks
  • 797 Answers
Make sure that the little lever or slide switch on the side of the card is in the right position.
As you look at the card with the contacts facing down, the switch should be set to the lowest position.
The SD card can be set to write-protect by moving the switch or lever up.
If that is not working, then there is some problem with the camera.
Posted on Jun 22, 2008
On my Samsung Digimax S800, when I put the memory card in, it says to check sd card. What do I do about it?
When the card worked before, check if you did not switch the lock switch down. And check all contacts on the card and in the camera. They should be clean and shiny.
When you recently bought a new card you could have bough a SDHC card and these won't work in your S800.
The S800 only accepts MMC and SD cards, The SDHC and SDXC cards won't work.
A few years ago you still could buy 4 Gbyte SD cards. Now even most 1 Gbyte and 2 Gbyte cards are already SDHC. SDHC was introduced at least 7 or 8 years ago, so all new devices accept SDHC. The SDXC was introduced at least 4 years ago, so in a couple of years, you perhaps only can buy these cards?
Feb 21, 2015 | Samsung Digimax S800 Digital Camera
I have an vivitar vivicam s128 when I put my sd card in it says card protected what can I do
Sure you did not lock the card? The little notch should be in the up position as in the picture. Then the manual says you can use SD cards up to 32 Gbyte, but I can't find anything about the cameras compatibility with SDHC cards. So try the camera with a SD card. The used to make SD cards up to 4 Gbyte, but today, even 1 Gbyte cards are SDHC.
1- check Lock
2- Use SD card to see if your camera works with that.
See a 4GB card, only SD, but not for sale anymore.
25340409-k1yyfchjsxnzfpw0twyoxddp-4-0.png 25340409-k1yyfchjsxnzfpw0twyoxddp-4-2.png
Dec 27, 2014 | Vivitar Cameras
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
When I now try to use a 4gig memory card it always says the card error or card locked. I have tried card in both positions but it still says it is locked. I have tried with 3 different 4gig cards. What...
You may be restricted to using only SD cards, and many 4gb cards are actually SBHD. My sister had this problem with her camera and by putting in a new 2 gb SD card, her camera worked fine. You may need to shop online in order to find an SD card, but they're widely available online. It costs about the same for 2 2gb cards as one 4gb even though they aren't as convenient.
Nov 11, 2010 | Canon PowerShot A540 Digital Camera
Memory caed error please check the card
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Jul 18, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Camera says that my sd card is locked and it isn't
try to put some glue on a your card lock , in unlock position. But be carefully do not delete your picture by accidentally.
May 31, 2010 | Canon PowerShot A710 IS Digital Camera
Trail Sentry 11-9200 Digital Camera: I bought this camera from a store that used it as ...
Bushnell recommends to only remove or insert cards with power off, or it can damage the SD card.
Borrow an SD card that fits in your camera and test it. If this solves the issue, buy a new SD Card here.
May 16, 2010 | Bushnell Trail Sentry 11-9200 Digital...
SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Apr 07, 2010 | Canon PowerShot A75 Digital Camera
Screen reads SD CARD locked
I have 17 of these cameras and for some reason after a while some of them develop this problem. It is very frustrating but I can usually get them to work by taking disk out, turning on camera, put in auto mode, wait for delay to switch to ready then put card in. I works most of the time and if not turn it off and keep trying. Some kind of glitch in the computer I guess. Hope this helps.
Nov 23, 2008 | Moultrie MFH-DGS-100 Digital Camera
Memory card is write protected
thought the cards have a little tab on them so they can be "write protected" it is a little plastic tab on the side of the memory1.gif card you slide up and down. I know most SD cards1.gif have it, CF cards dont so if its anything besides SD memory its probobly the memory card or some little switch or somthing in the camera that tells the camera when the card is in the "Locked" or "Write protected" mode.
Looking at my SD memory cards1.gif they have a little arrow on the edge and they say "Lock" pointing down, the slider is up. Move yours both ways, maybe it has a bad connection in the card (im not sure what it actualy does) or its in a position the camera thinks its locked?
Jan 15, 2008 | Nikon Coolpix 4500 Digital Camera
Cameras Logo
19 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
