Moving the start bar in windows around the screen
My computer start bar/Taskbar is on the rigth of my screen i am trying to put it back in Default pos i am having no joy with the windows help
Im runing winXP system 2GB ram 108GB Hdd No added display cards
TFT19'' my nan is learning to use a computer also it will be a problem at next lesson with the bar like that Thank You
    Guru:
  • 1,342 Answers
Just left click on it and drag it to where you want it.
Posted on Jun 22, 2008
How to lock the task bar when it does not showing on screen
It may be set to auto hide. Try moving your mouse cursor to the edge of the bottom screen. If it doesn't show up, try the other three edges of your screen.
Once located, right click on the task bar and choose "Properties" from the menu. On the window that pops up, simply uncheck the auto hide option. If the bar is already on the bottom edge, click on the "Lock the taskbar option." If not, drag the bar to the edge of the screen you prefer and then lock it.
Jul 04, 2016 | Acer Extensa Computers & Internet
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
Windows start bar has completely gone
Sympton
You cannot see the taskbar (which contains the "Start" button) anywhere on your desktop.
Causes
  1. The taskbar may be hiding at the bottom of the screen after being accidentally resized.
  2. If the presentation display was changed, the taskbar may have moved off of the visible screen (Windows 7 and Vista only).
  3. The taskbar may be set to "Auto-hide" (Windows XP with Service Pack 2 only).
Solutions
  1. Put the mouse pointer on the bottom border of your screen.
    • If the pointer turns into a double-arrow doublearrow.gif, click and drag upwards.
    • If your taskbar isn't hiding at the bottom of the screen, try moving the mouse to the right, left, and top edges, looking for the double-arrow.
  2. Press the Windows logo key and the P key on your keyboard to bring up the presentation display mode options.
    • Make sure "Computer Only" is selected.
    • Use the arrow keys to toggle between options and Enter to select the correct display mode.
  3. Press the Windows key on the keyboard to bring up the Start Menu
    • Right-Click on the taskbar and select Properties.
    • Toggle the 'Auto-Hide the taskbar' checkbox and click Apply.
    • If it is now checked, move the cursor to the bottom, right, left, or top of the screen and the taskbar should re-appear.
    • Repeat step three to return to your original setting.
Dec 04, 2012 | Computers & Internet
How do I move windows/dialog boxes around on HP-Mini screen - and get them to stay there? Just bought HP-Mini 110-3100. Installed Flipshare but can't access all functions. Program window is too large for...
no OS stated is it windows what windows?
so this is a pure FLIPSHARE question rigth
how to use that APP.
what version flip-share, ever think to ask them.?
v5.12.3 runs on xp to w7 are you using that version?
do ask them what dont work if in fact is is there issues
from your post I can not see what you are attemption
we are blind here, can see you click or do what?
Jul 03, 2017 | HP Computers & Internet
Task bar consumes two rows at bottom of screen
Hi, try this to fix the problem. [right] click on the "Taskbar" select to open the "Properties" short-cut, next in the [Taskbar and Start Menu...] window, click on the Taskbar button, and [un-check] every box. Next, open the Toolbars window, and [un-check] every box, "Apply and OK changes." After you have finished doing so, "restart" the Computer. When you are back to the "Desktop window, open the Taskbar Properties again, and put a {Check mark in all the boxes of the items you want present, to view}. I hope that it works for you; thanks for using Fix'Ya, and if you find the time give a "rating" for the help, thanks again.
Jul 12, 2010 | Gateway Computers & Internet
Missing task bar - running vista
Sounds like explorer.exe is not running:
1. Hit Ctrl + Shift + Esc at same time.
2. Windows Task Manager should open.
3. Hit File on top menu.
4. Select New Task.
5. Type explorer.exe and hit OK
That should bring your task bar back.
Jun 02, 2010 | Microsoft Windows Vista Home Premium...
No volumn controll on taskbar
Try and rigth click on the bar >propertys>customise enable hear or reset default setings
Dec 18, 2009 | Computers & Internet
Windows XP taskbar sink
This happens because you have set your Taskbar to Autohide mode.
Do the following steps:
  1. Move the mouse to the bottom of screen and let the task bar come up
  2. Right click on task bar
  3. Click on properties
  4. On the Task bar Tab Unchek Auto-hide the task bar
  5. Click Apply
  6. Press OK
Thats it
Sep 25, 2009 | Dell Computers & Internet
Task bar is missing on bottom of screen after pc wakes up.
mine does this with windows 7, right click on desktop and open 'personalize' then open 'taskbar and start menu'
From here choose to move your taskbar location to the side of the screen and click apply. it should return, then just tell it to go back to the bottom.
Sep 18, 2009 | Dell Studio XPS 435 PC Desktop
Task bar still not found dropping & dragging
  1. goto my Computer
  2. left hand ide youl get controlpanel
  3. taskbar and start menu
I sugest you you change to clasic so that the taskbar is reseted and the ten restart an do allthis again and change it like it was. You can also bbot in safe mode, by tapping F8 @ boot screen and change the setting there when you restart it should be OK
Jan 04, 2009 | Toshiba Satellite A75-S231 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
