Putting a new playback head into an audio cassette deck.
I have a Technics audio cassette deck and I played a head demagnetizing tape in it. This I have since discovered I should not have done! (since the head was not the type you usually find but of a different technology altogether). Many years ago I used to service/repair profession tape ecorders so I feel if I could get the service manual for this deck and acquire a playback head I should be able to repair this deck myself.
Thank you,
Patrick Doherty.
  • 1,512 Answers
Hi PATRICK
What happened when you used the head demagnetiser tape? Did chew out the head? If you can give me the model of the deck I can make some enquiries to help you sort it out.
regards
robotek
Posted on Jun 29, 2008
I have a TDK HD-01 head demagnetizer for cassette decks, but I have lost the instructions. Could you help?
Hi there.
First - Turn On The Tape Demagnatiser (should be a switch on it)
Second - Insert into cassette player
Third - Turn On cassette player
Fourth - TURN DOWN VOLUME ON AMPLIFIER TO MINIMUM (This is essential!)
Fifth - Press Play on cassette player
Sixth - After 10 seconds press stop on the cassette player
Seventh - Remove the cassette demagnetizer from the cassette player
Eighth - Turn off the demagnetizer and put back in it's usual storage place
AGAIN, MAKE SURE THE VOLUME IS TURN TO MINIUM WHEN USING THIS AS THE NOISES CAN DAMAGE SPEAKERS.
Jan 07, 2011 | Audio Players & Recorders
Faulty technics rs tr333 twin cassette deck,no sound or led idications,tapes do work but nothing coming out of unit,can anyone help as i have never had a fault with the system,had unit from new its a few...
It is likely the circuitry that senses tape head output and amplifies it has failed. The part of the circuitry where heads are switched from record to playback may be at fault.
Mar 25, 2010 | Technics Audio Players & Recorders
Technics RS-TR373 is chewing tapes
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
Jan 18, 2009 | Technics RS-TR373 Single Cassette Deck
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Tape shows playing but no sound
Is sound at the headphone socket?
Does the meter show audio output?
If the answer is yes to these questions check that the connections to the amp are correct and the amp is set up is ok.
Regards
John
Nov 25, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272-no sound during play
CHECK CONNECTIONS AT THE BASE OF THE READ HEADS AS THEY HAVE A TENDENCY TO CRACK OVER A PERIOD OF USE. CAREFULLY STRIP BACK AND RESOLDER, REMEMBER TO LEAVE SOME SLACK AS THE HEADS REVOLVE ON TAPE REVERSAL.
Jun 09, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
129 people viewed this question
 Grubhead
Grubhead
