Question about LG Televison & Video
Dvd jam in tray - LG Televison & Video
    Sergeant:
  • 291 Answers
Press the open\close several times in so meny seconds.,then place player facing down (NOT ON ITSELF!!) and continue pressing button. The plastic gears could have lost its teeth or the gears are sliping.
Posted on Jun 22, 2008
Emerson EWC19T3 tray will not open
Maybe it can---an expert needs to take unit apart to see if just freeing the one jammed in the door can be cleared --it is 50-50 chance.
Apr 16, 2012 | Televison & Video
Can I open a jammedDUW1616/ARR DVD
Look on the front of the tray where the eject button is There should be a small round hole, this is for ejecting a stuck disk. Just open out a paper clip and insert in to the hole and press until the tray opens.
Jan 31, 2012 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
I hv a JVC th-s3 dvd player who's dvd tray is locked. none of the solutions on this forum hv worked. pls help. thanks. chris
You have to remove the changer assy. See why it's jammed and retime it. I have seen a lot of these with jammed changers. If you remove the dvd assy from the bottom there are 2 gear sets to the side. 1 moves trays up and down and the other draws tray in and loads the disc. All I can say is if you are mechanically inclined you can figure it out. If not have it serviced.
Jan 01, 2010 | JVC TH-S3 System
After printing a CD lable, I get a paper jam or CD/DVD tray jam, when the tray is already removed for the next CD. I must re power the printer to print one or two CD
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I read from other comments that the markers on the tray must be clean. As I already printed several hundred CD/DVD the leading marker on the tray was badly marked. Tried to clean it with an eraser but I got very bad result. I tough I could paint it with some white paint but instead I use micro correction tape and white the marker. I had it working for 10 CD in a row, not bad for a cheap patch.
Where can I order a new CD/DVD tray
Oct 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Dvd jammed within the dvd player
There should be a small pin hole located on the front of the DVD tray. Gently push the end of a paper clip or something similar into the hole to release the tray.
Sep 27, 2009 | Grundig GU19WDVDPCX 19 in. LCD TV
DVD trays are jammed and will not open. It
Look for a tiny hole directly underneath the tray either left or right of the tray. alos of a tiny hole that may be anywhere the two panels meet, use a paperclip "metal", to push in those holes, it will offer some resistance but open the tray. It sounds like the motor has gone out or jammed with dust and debris. -Hope this helps -Regaurds.
Aug 09, 2009 | Panasonic Audio Players & Recorders
Jammed tray
try checking the tray for something that jams the tray.
May 27, 2009 | Yamaha DV-C6660 Multi-disc DVD Player
Locked??
I had this problem, it was a jammed disc. I disconnected the dvd player and removed the cover. Then I checked out the trays and sure enough a disc was jammed. It took a bit of very gentle work to free the disc as the jammed tray needed to be unlocked so the tray self slid and released the offending disc. Once that was done I placed the cover back on and reconnected the wiring...and all was well.
Jun 02, 2008 | JVC TH-M606 System
Jammed dvd
Open up the unit. Find the DVD carriage you might be able to extract the DVD this way, but if you are not find the DVD carriage load and umload motor and manually turn it. This will eject the DVD.
Aug 27, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Televison & Video Logo
79 people viewed this question
Computer Repairing
Computer Repairing
