Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Okay...I have the same problem and thanks for the reference...
Now, how do I go about actually replacing the short hose? I removed about 15 screws around the handle and lower unit but could not get my hands around the upper hose connection! Is it glued, screwed? How do you get access to it?
  • ibiggs Sep 07, 2008
    Same problem. Suction decreased dramatically. I found that the lower hose was leaking. Bought a new part but can't get to where it is attached to replace it. Took out about 15 screws but unit still isn't coming apart as it attached below. Any info would be helpful. Thanks.
  • ecaruso10 Sep 12, 2008
    I finally figured it out...there were a few more screws holding the two halves of the shell together on the upper component. I only discovered them after carefully examining the unit in daylight (dim incandescent lighting in my kitchen simply isn't enought.
    Anyway, the hose is not glued but snapped in place. It does come out rather easily once I was able to fully disassemble the unit.
ECaruso was exactly right. I I had taken 15 screws out. Once I located the 16th screw I was able to open the top compartment enough to snap the old hose out and the new one in. (Not quite that easily, but not too much of a problem.) Thanks.
Posted on Sep 19, 2008
Same problems - power nozzle motor does not work after cleaning the brush and pressing the reset button. Also the handle button which turns on the nozzle does not light up (my wife thought it lit up...
This is a pretty common problem on the Guardian, and it's usually caused by 1 of two things. Both are pretty simple fixes. The first thing you should try is simply eliminating the wand assemblies from the vacuum cleaner. So remove the hose from the upper wand, and disconnect the lower wand from the power nozzle. Now try connecting the hose directly into the power nozzle and turn on the vacuum cleaner, and power nozzle. Does it work? If yes, then one of your wands has gone bad, and you'll need to replace it. Here's a link to the wands on our website if you need purchase a new Guardian wand;
Electrolux Guardian Replacement Wand Assembly
If the power nozzle still won't come on, then you may have a much simplier problem. This is either a terrible design by Aerus, or they knew this was going to happen, and made it this way so you'd have to take your machine into to have them service it. It's a very simple problem usually.
Look on the neck of the power nozzle. You will see a small circle indent on the front part of the neck located underneath of where the wand connects into the neck. This is actually a cover that hides a screw below. Simply use a small flat head screw driver, and pop off the small circular cap that hides the screw. There is a Star bit screw underneath. I believe it's a T15, but it may be a T10 sized screw. Use I believe a T15 Torx screw driver and remove the screw from the neck.
Once the screw has been removed, Use a flathead screw driver, and pry the front cover of the neck off. It shouldn't take a lot of force, and should come off pretty easily. Once this has been removed, you should see to metal pins, and two lead wires. What happens is the lead wire becomes disconnected from the metal pin, which then prevents the power nozzle from turning on. Simply reattach the lead wire into the metal pin, and snap the front cover of the neck back on. Put your screw back in, and your screw cover (or you can just leave this part off, you'll probably be having to remove it frequently to reinstall the lead wire, lol).
If neither of these two problems fixed your machine, then it sounds like you may have a bad hose assembly. Hopefully this isn't the case, and it's usually not. 9 times out of 10, it's just the lead wire that's come loose. If you do however need to buy a hose, here's a link to the Guardian hose on our site;
Electrolux Guardian Replacement Electric Hose Assembly, Blue Color
If you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Electrolux Guardian Bagged Canister Vacuum
Tip
How To Replace Brush Turbine on Hoover SteamVac When Brushes Don't Spin
When the brushes stop spinning on a Hoover SteamVac, it can be caused by several things. In order to diagnosis why your brushes aren't spinning, please view the diagnosis solution I have done on Fixya:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you have diagnosed your machine, and found that the internal receptacle is not spinning, then you'll now need to replace your turbine. This tip will explain in detail how you'll need to complete this repair.
Here's what you'll need to complete this repair:
- Hoover SteamVac Replacement Turbine Brush Gear (several different parts for different models)
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see-thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before you tighten the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover F5899-910 SteamVac Vacuum
Tip
How To Replace Brush Turbine in Hoover SteamVac's When Brushes Won't Spin
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover F5886-900 Steam Vacuum
How do I replace the spinning brushes?
Chris J.
GoVacuum
Apr 17, 2010 | Hoover F5906-900 Upright Steam Vacuum
Problems with Beam central vac
My Beam central vac has started turning off after about 10 minutes of use. I thought it was the hose, but the hose in the garage does the same thing, and I've also tried the other outlets, and the same. The canister was just emptied about two weeks ago. I have also reset the breaker, and unplugged and replugged in the system. Could this be a bad motor?
Feb 22, 2009 | Beam Industries 2775 Serenity Plus Central...
Tip
How To Replace The Brush Turbine in Hoover SteamVac's When Brushes Don't Spin
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover F5842-9RM Steam Vacuum
Tip
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
KENMORE pROGRESSIVE WITH DIRECT DRIVE SUCKING NOISE
I had the exact same problem. The port is a relief valve to prevent the motor from burning out if the hose/bag are clogged. Check the main hose from end to end after removing the 3 screws that hold it to the body of the vacuum near the handle. If that's clear then it's almost certainly clogged in the short tube that goes from the beater bar housing to the hose extension (where the flex tube attaches). There are two ways of going about this.
Option 2
(the way I did it) -- Lock the base on the upright position and turn the unit over. Unscrew the 12 or so screws in the black base. You'll need to depress the release pedal when removing the screw at the end of the pedal. Once you have all of the screws removed carefully wiggle the base loose. You do not need to remove it completely to access the short flex tube. Clean it out and replace everything in the opposite order from how you removed it.
Option 1 (what I would do next time) -- Cut a wire coat hanger and make a small 1/2" hook at the end. Bend the straight section into about a 4" radius arc leaving plenty to handle at the end opposite the hook. Carefully snake the hanger down the tube and pull out the giant clump of hair and dirt that's clogging the vacuum.
cheers -- eric
Nov 15, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
U6446-900
from the underside: 1. remove 4 screws holding agitator cover in place 2. remove 2 screws (black screws) holding hose retainer in place, pull hose out through top 3. remove three screws, 2 long, 1 short holding top cover: short screw is at center of inside of brush housing, long screws are inboard of wheel axles, and slightly forward (all of these screws are aluminum colored) 4. from inside surface of each side, at approx the center, locate and push down on ledge inside right and left inside with a screwdriver to slightly displace the plastic ledge that holds the cover on; this ledge-lock-detent can be released with your fingers. You'll have to support the drive mechanism to allow the top housing to drop free. 5. remove housing, turn vacuum over, then go find the torx driver you need to disconnect the cable. Good Luck MB http://in4m8ion.com
Aug 19, 2007 | Hoover U6630-900 WindTunnel Bagless...
Tip
How To Replace Turbine Gear in Hoover SteamVac's When Brushes Stop Spinning
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
47 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
