Question about Microsoft Windows XP Home Edition
Auto restart My computer turned off itself after 10 - 15 minutes for every operation. What is the solutions for this problem. Contact email hmtlkt@gmail.com.
  • bcat123 Jun 22, 2008
    Are there any more solutions of how to fix auto restart?
    After 10 - 15 minutes turn off and restart computer itself.
  • 128 Answers
It's a heating issue. If you haven't noticed yet, the LX6810 comes stock with 2 fans, a CPU fan and a power supply fan. In other words, there are no case fans. There are spots to have a 120 mm case fan put in on the rear of the case (exhaust) and a 80mm case fan on the front of the case (for air intake). I'm guessing Gateway wanted to save a few bucks by not including case fans.
I recently upgraded my LX6810 with a graphics card, sound card, new power supply, and a few other things. With all this, I also installed a 120 mm fan on the back and 80 mm fan on the front. I have not had any heating issues since, and I am running very hardware intensive programs.
Simple solution: Buy the two fans and install them yourself for 15-30 bucks depending on how fancy of fans you want. Be sure to get the right connections to power the fans (either throught the motherboard or directly the power supply).
A few notes:
1. When hooking one or both fans to the motherboard header "SYS FAN", it appears that there is no speed control or enough voltage being supplied to the fans. They run about half speed all the time. It does, however, show the speed of the fan in the BIOS and Speedfan.
2. I just upgraded to the latest BIOS update Gateway came out with. The only change I have noticed is the CPU fan runs at a constant 3250 RPM, instead of 1400 RPM. It appears to me that Gateway was getting enough returns because of heat issues that their simple fix was to up the CPU fan speed. This has disappointed me greatly because I enjoyed the quietness of the machine. Now it is a constant howl.
The interesting thing is, the CPU temp isn't the problem, I believe. The CPU runs very cool; the cold air intake helps a lot. It is the rest of the components that are overheating. Feel the heatsink right below the processor after using it for some time. It will be burning hot. The higher speed of the CPU fan will pull in more air to the case, but not very efficiently at all.
3. I can't seem to find a way to change the speed of any of the fans. Not through BIOS or Speedfan. I think either the motherboard doesn't support it or Gateway's BIOS is preventing this
Posted on Jun 02, 2010
    Guru:
  • 1,342 Answers
It may be overheating or the power supply may be failing.
Posted on Jun 22, 2008
  • Georgia B
    Georgia B Jun 22, 2008
    Is it turning off or restarting?
  • Georgia B
    Could be your video card. Read This Post and make sure you have the latest video drivers for your video card.
Hi I have a BMW E90 320i 2006 When I turn on the auto wipers they work great for about 5 to 10 mns then they stop you can't use them manually or auto until you turn off the ignition
check the relay switches under the hood . Sometimes these relays get stuck and they don't work right. Or you might try to disconnect the negative terminal of your battery for a few minutes then let the ECM (the computer) reset itself.
I'm not saying that is the solution but it is a possibility.
Nov 02, 2017 | BMW Cars & Trucks
Casio CDP - 120 turns itself off
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
If it turns itself off while playing, I would try to buy a new AC Adapter to test. DC cable of AC adapters are often broken internally after much "bending".
Jan 06, 2014 | Casio Music
Nokia e72 auto restart problem in 10 sec
Sep 06, 2012 | Nokia E72 Smartphone
We buy a new computer and we are going to set up an O.S. what would be d 1st step
Well, the Ist step is to enter the setup by pressing delete as the system turns on. Now choose BOOT DEVICE PRIORITY and make the Ist preference CD ROM and second one HDD. Now press F10 to save and quit. When the system restarts, it will ask you to press any key to boot from CD. Then you will have to press a key within 3 seconds.
After one round of copying completes, the system restarts itself. On restarting, again press delete and make the BOOT DEVICE PRIORITY as it was earlier i.e; HDD Ist and CD ROM second. Press F10 again and upon auto restarting, the installation will resume and complete itself.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Jul 09, 2011 | Computers & Internet
My computer restarts itself and won't load xp anymore
This sounds like there is something such as a USB device trying to be read on startup. Once you have disconnected the USB Device from your PC, try reloading your PC again, if this doesn't work there is a problem with one of the devices, i.e. video card, network card (wireless).
Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Jun 30, 2009 | HP Computers & Internet
When I give to my computer th driver it work auto restart
dear morshedy, the blue screen is usually comes when thereis a problem with the computer system files. and it could also result to sound problem. i wish you could start with solving the blue screen this can help us to solve the sound too.
solution:
you need to reinstall the operating system your using by the use of operating system CD.
please be free to contact me for more assistance.
Dec 12, 2008 | Asound Express 32 Bit ALS-4000 PCI Sound...
Shuts down, then restarts itself
That can be caused by a number of things , your best bet is to take a look @ this guide...since there are so many things it could be , this breaks it down to make it easier to figure out where it is coming from:
http://www.aumha.org/win4/a/shtdwnse.php
Hope that helps you out!
Oct 07, 2008 | E-Machines etower 500i PC Desktop
Pc restarts automatically and unexpectedly
Good Evening Sunnyseber :
Hope that you are wellJ
You did not indicate the type of Operating System.
This document pertains to HP and Compaq computers with Windows Vista. If Windows Vista suddenly starts without warning, or restarts when you try to shut it down, it may be because your operating system is set to automatically restart when certain system errors occur. This feature of the Windows Vista operating system can be disabled. Use the information below to disable the Automatically Restart option. NOTE: In addition to the steps in this article, updating video card drivers is known to resolve many of the problems that can cause the computer to restart. Step 1: Disabling Automatically restart option to view error messages You can prevent the computer from restarting by turning off the Automatically Restart option:
  1. Click Start c00971562.gif .
  2. Right-click Computer , and click Properties
  3. Click Advanced system settings .
  4. Click the Advanced tab and select Settings in the Startup and Recovery section.
  5. Remove the check mark next to Automatically restart under System Failure .
  6. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
  7. Restart the computer. NOTE: The computer will no longer restart automatically when a problem occurs. Instead a blue screen appears with more useful information. You can now search for a resolution using the text from the error.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Disabling auto restart in windows xp
JUST FOLLOW THESE METHODS
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
HOPE SO YOUR PROBLEM SOLVES BY THIS SOLUTION
May 09, 2008 | Microsoft Windows XP Home Edition
Is the auto power save function employed?
Yes, this camera has an auto power save function to save power.The camera turns off the displays and unnecessary functions if an operation is not made within a minute. (Power Save Function).To restore the power, press any button or key, or turn the exposure mode dial to another position.The length of this period is selectable from 1 min., 3 min., 5 min., or 10 min. in the section 1 of the setup menu.The LCD monitor always turns off if any operation is not made in a minute, and this period cannot be changed.If no operation is done within 30 minutes, the camera shuts itself off. Pressing the power button resumes the camera operation from this condition.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Microsoft Windows XP Home Edition Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
