Question about Canon PIXMA MP830 All-In-One InkJet Printer
U150 canon pixma MP830 "the following inktank can not be recognized" magenta. Please help, Thanks, Ted I had this problem with the original yellow tank that came with my MP830 printer. Removing and replacing the ink tank multiple times, each time I wanted to print, allowed me to print. With a new set of Canon ink cartridges I have the same error, but with the magenta cartridge, and nothing I do will allow me to print. Removing and reinstalling the magneta ink tank worked for a week or so. Then just opening and closing the printer cover several times worked for a few days. Now I get the U150 error every time I try to print, and I can't get rid of it. (Although for variety, sometimes it says I have two magnent ink tanks installed) Now I can't print at all with this 3-month old printer. Very frustrating!
    Genius:
  • 1,847 Answers
Clean the lower end the tan and install it back
Posted on Jun 22, 2008
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error code U150 on Pixma MP830
U150 error is ink tank not recognized, it happens alot on the y cartridge. i would advise you to get a version 3 cartridge. on the back of the cartridge if you hold it in the right light you will see a code like 2AHU 3FGH, this tells us its a version 2, i would maybe buy a version 3 or 5 with a updated chip, this will work fr you, if the fault is still there then the 4 contacts in the carriage unit that reads the cartridges is prob bent or broken!
hope this helps
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Ink cartridge
Got this same U150 error code( Ink Cartridge not recognized) tried reinstalling... no luck... got a new one... no luck.... now collecting dust after I completely disassembled my MP830, checked all connections and reassembled it... stil the same U150 error code....and a new HP 7280 is on its way.... if a fix comes up for this.... I will have it fixed.. GREAT all-in-one! This is the only problem I have ever had with it...
Jun 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I have had this problem repeatedly lately. To try the Stop/Reset solution already mentioned, I turned on my infrequently used Canon Pixma MP830. Most of the time at a fresh startup it gives an alarm message "the following ink tank cannot be recognized" OR "there are two of the following ink tanks installed" ??! for the single black 8 cartridge !, a Canon original. Of course, tonight it started just fine, but the methods I have used when it does not work because of these alarms are the following:
I open the top, wait for the cartridge carrier to center, unsnap the black 8 cartridge, then snap it back in and close the top. This sometimes works if repeated until the machine recognizes it. Sometimes I unsnap all the cartridges and resnap them. If this doesn't work, I remove the black 8 entirely and use a clean cloth to wipe the electrical contacts of the cartridge in the direction of their length and reinstall. It sometimes takes a repeated combination of these steps and sometimes the two different alarm messages will appear alternately. There does not appear to be any logic to it. Once the machine does recognize it, it works just fine.
However, if the machine is turned off, many times when it is turned back on later I have to go through all this frustrating rigamarole again. I hope it is a glitch with this particular cartridge (fairly new) and not the machine. Next time I get the alarm messages I will definitely first try the Stop/Reset button solution suggestion, but I thought I'd add my two cents solution, which so far has eventually caused the machine to recognize the cartridge.
May 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Ink cartridge
clean the contacts of the inkcartridge chip e.g. with spirit
or
Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shown correctly
May 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
INK TANK
U150 is a 'faulty electronic chip on the tank' error. If you installed a new Canon OEM tank then probably the chip on the new tank is bad.. Take that tank back for a replacement.. If you installed a Clone(non-OEM) tank, then that one will only work if you retrieve a chip from a known good OEM tank and glue it on to it. Clone(non-OEM) tanks all come without chips.
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
UO71 More than one ink tank of the follwoing color is installed/U140 The following ink tank cannot be recognized
Had the same error after replacing my black ink om my MP830.(UO71) I Put some Methylated Spirits on a cotton tip and gently cleaned the cartridge chip (allow it to air dry). This fixed my problem!
Aug 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
358 people viewed this question
old marine
old marine
