Question about Brother MFC 210C All-In-One InkJet Printer
Black won't print
Hi, I've changed the ink cartridge several times. Black won't print. Other colors print in there respective slots, fine. HELP thanks, Jim
  • sbasrom Jun 22, 2008
    what ever i type in microsoft woud not print but if i paste something from the internet then it prints.
  • Anonymous Jul 20, 2008
    I have recycles over 30 times, it still won't print black.
Had same problem. Do not go buy a new one just yet. I was just about to myself. Took ink remover and brushed it on one side of my thickest copying paper. Be sure ink removal side is the print side. Make about 3 copies which use the color that is not working. Black but works on any color. Clean cycle a few more times If you start to see the color appear in spots do not give up, Send another copy with ink remover a few cleaning cycles and your printer will be as good as new. PS If you do not use the printer much send a ink remover paper threw when finished to keep tips from clogging.
Posted on Jul 24, 2008
I have this same model printer and had this same problem. I solved it by running the cleaning cycle repeatedly (30 times or more). It nealy drained the black cartridge, but they're cheap compared to a new printer ($100 for the mfc240c that replaced it). Press the ink button to the left of the display. Select "test print" and "print quality from the menus, then hit print. After printing, the display will ask if quality is ok. Press 2 for no. It will ask if the black was ok, press 2 for no, if the color looks ok, then press 1 when it asks if color is ok, then press 1 when it asks to start cleaning. In a minute or so, it will beep and tell you to press start. Once the sheet prints again, repeat the same sequence. I didn't even wait for the display, I would just press 2,2,1,1, each time it printed. At first the black section was blank, the one dash appeared, then two or three. I gradually gained on it until I had most of them working again, then let it set overnight and ran a few more cycles the next day and it finally all started working.
Posted on Jun 23, 2008
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
Hi, I've changed my Brother printer ( MFC-495CW) inobella recently but the color black dose not work. what to do?
this happened to me, too. printer starting using all of my yellow ink.
The ink container was the problem, defective. it took several changes for it to print in black again...5-10 cleanings.
make sure the black cartridge is not defective by trying another one in it's place. if you can, use the yellow for the black slot, then switch back a few times ( I tried to re-install the drive, but the in was the problem). Good luck.
Oct 27, 2010 | Brother MFC495CW
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Black won't print!!
Hi denzirelli, Apparently several reviews of this printer say it is known for poor print quality when dealing with graphics AND the tubes can become blocked. As far as troubleshooting goes if you haven?t done so already purchase a new set of official Brother ink jet cartridges, black and color. The newer ink jets are a lot smarter and remember the last couple of cartridge serial numbers. If that doesn?t work then try running the nozzle cleaning utility a couple of times. If that fails call the Brother and let them walk you through the troubleshooting process. I don?t suggest you lie, just don't volunteer the fact that you were evil and tried to deprive them of their profit. Worst case they won?t do a warrantee replacement, best case is you?ll have a working printer. If you don?t want to pursue the above option or if tech support won?t help then we?re back to troubleshooting again, when you say it doesn?t print black does that mean colors do print? If that?s the case then I suspect the black tube or the nozzles are blocked. From what I?ve read it?s a little bit of a pain to remove the print head but the key is not to disconnect the tubes. Remove the print head and the cartridge container as a unit. The ribbon cables have to be unplugged from the circuit board. Disconnect the belt and you should be able to take the print head out and clean it. Let us know how it turns out and don?t forget to rate the posting.
Jan 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
190 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
