Question about Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive
Installing old drive into new drive
My old acomdata external stopped relaying to my PC and my Laptop. My only thought is to purchase a new acomdata external drive and remove the new drive and install the old drive into the new shell....will this work?
  • nahualli Feb 12, 2009
    I have the same problem, but the circumstances surrounding my failure was losing the unique-looking power corde for the drive itself. I tried taking the drive out and putting it in a standard rocketfish enclosure, but it is not recognized by my machine.
    The only thing I can think of is to get another Acomdata drive. Which brings me to this page :(
    What specifications should I look for in a new enclosure? I think the problem is that other enclosures don't provide enough power?
    -M-
  • 304 Answers
If the problem is in the controller inside the case which in 99 percent of the times it is, This will certainly fix your problem. The MTBF(mean time between failure) of harddrives is 100,000 hours of operation. Also, any external case can be used that matches your hard drives specs...size, IDE, SATA ect...
Hope this helps you,
George
Posted on Jul 16, 2008
  • George Kohler
    George Kohler Jul 23, 2008
    Please log in and rate this comment fixya if it helped you resolve your problem. If it did not send me an E-mail with
    your phone number to geokohler@gmail.com And I will help you fix your problem. Do not rate the problem until We
    have it fixed.
    Thank you,
    George
    Ps. This is totally free or charge to you. I even pay for the call.
My husband has a 14 year old Dell computer. He purchased an Acomdata external drive around 2007. He is desirous of transferring the data from the internal drive on his old computer to his Acomdata e
He should be able to do that , Doris. Although it may be a slow process. His external hard drive is equipped with USB version 2.0. If his old computer is version 1.0 it may take a while. The good news is that the two versions are compatible. you can read more about USB here. P.S. I've done this many times with my external drive.
USB Wikipedia the free encyclopedia
Nov 19, 2014 | Dell Computers & Internet
Acomdata backup hard drive
open your cpu chk all cable then try to on
Jul 19, 2008 | Acomdata Computers & Internet
We have a Windows XP system on a 14 year old Dell computer.. We are desirous of transferring data from that system to a new computor. My husband purchased an Acomdata Hi-speed 2.0 external hard drive...
If both your Dell and the hard drive have USB ports you may be able to download directly. Other wise you may purchase an external drive and load the data to that. The external drive almost certainly will connect by USB.
Acomdata external hard drive not opening MBP
Acomdata Drive Not Recognized: I ran into the same issue. Actually the issue was with using an incorrect power adapter. It should be with power ratings of: Input 50-60 Hz 1.2A & Output 5V - 2A, 12V - 1.2A
Jun 22, 2012 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
I just purchased a external hard drive case to use bc i was upgrading my hard drive to my laptop. now my new laptop has the bigger hard drive and my old hard drive that came out of my laptop reads 4...
It sounds like your old laptop drive had 4 partitions on it.
If that is the case and you want it to be only one partition then you'll have to back up anything you want to keep in those partitions and reformat the drive as one partition.
You can reformat the drive using the Disk Management utility in Windows.
Dec 05, 2009 | Acomdata 250GB External Firewire HD 250 GB...
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Firewire problem I think - I have a Sony Vaio laptop, the firewire port is 4 pin, it is connected to a LaCie CD Burner via 6 pin and the burner is daisy chained to a AcomData external hard drive via 6 pin....
If the hub has an external power supply it migh do the trick. That way you can have a backup port if needed.
Make sure the hard drive isn't connected to the hub. Sometime windows doesn't see it when its connected to a hub.
Jul 14, 2008 | Computers & Internet
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive Logo
210 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
