1999 Chevrolet Silverado 1500 Logo
Posted on Nov 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the basis for the classification of levers?
Anonymous
Level 3:
  • Master 4,793 Answers
  • Posted on Nov 22, 2010
Anonymous
Master
Level 3:
Answers
4793
Questions
0
Helped
1544762
Points
14368
Levers are graded as to the ratio of force needed to move a given weight.this is calculated from the fulcrum to the end of the lift point(upwards motion) then from the fulcrum to the end of the lever arm.(downwards motion)these clculations vary dependong on the lengths of (say)a crowbar.this being the simpilst of levers.
Error code b00a0.00. How do you go about this error with out dealer
Unfortunately unless you specify 'year make model' questions like this are hard to answer. I doubt it is on a Seat (pronounced See-At) the Spanish Car company. There are categories for every 'make year model'.
For $10,000 you could buy a new car!
B00A0 OBD-II - Occupant Classification System (OCS)
https://repairpal.com > obd-ii-code-b00a0-occupant-cla...
Code B00A0 stands for Occupant Classification System (OCS). Children and small passengers can be injured during airbag deployment.
1helpful
I have a 2006 Polaris MSX 140 jet ski and it has been sitting unused for nearly 3 years the Forward/Neutral/Reverse lever is jammed, how do I loosen it?
if there is a cable on the end of the lever , replace the cable assembly
if the lever is direct connection, spray with an anti rust penetrant on a regular basis for a few days then try to move it
try using localized heat from a butane torch to break the rust / corrosion seal while trying to move it
How do you fix error code U0151 in a 2014 Lancer?
i'd start by rechecking the "MDS on" install to make sure all connectors near where you were working are well seated. also recheck where the previous harness would contact. i find it really hard to beleive that the old harness was too short. improperly routed perhaps, but too short???
U0154 - LOST COMMUNICATION WITH OCM (occupant classification module)
  • When Monitored:
  • With the ignition on
  • IOD fuse installed
  • FCM is configured correctly
  • Set Condition: Bus messages not received from the Occupant Classification Module for approximately 2 to 5 seconds.
Possible Causes
CAN B BUS CIRCUITS OPEN OR SHORTED
DTCS RELATED TO BATTERY VOLTAGE, IGNITION, OR VIN MESSAGES
FCM NOT CONFIGURED CORRECTLY
OCCUPANT CLASSIFICATION MODULE
OCCUPANT CLASSIFICATION MODULE POWER AND GROUND
MODULE THAT SET THIS DTC
OCM is located under passenger seat. make sure it's connector isn't loose.
If you need further help, reach me via phone at https://www.6ya.com/expert/marc_162a3912222e83a4
Airbag codes B1206 B1204 B223D are on 2006 dodge magnum srt8
B1204 communication w/occupant classification module passenger airbag indicator circuit low
B1206 passenger airbag indicator circuit open
B223D occupant classification module DTC present
You either have a bad passenger airbag or the sensor that tells computer it is present
7helpful
2answers
Codes b1650 & b1785 on a 06 corolla came on what it posibly be?
B1650 Occupant classification System malfunction there are 4 possible trouble area No.2 floor wire,Front RH seat,center air bag assemble.
B 1785 Front occupant Classification Sensor LH collision Detection there is only one possible location to set this code Front seat LH
2answers
Need engine oil capacities for a 2.7L Hyundia
Lubricants and capacities
Engine oil options
Ambient temperature range Cold climate
Engine oil grade SAE 5W/30
Engine oil classification API/ACEA SJ/A2
Ambient temperature range Moderate climate
Engine oil grade SAE 10W/30
Ambient temperature range Moderate climate alternative
Engine oil grade SAE 10W/50
Ambient temperature range Hot climate
Engine oil grade SAE 10W/40
Engine with filter(s) litres 4,5
1helpful
2answers
Oil capacity for 3.0 crd
Engine oil options
Engine oil classification API/ACEA CI/C3
Engine with filter(s) litres 9,5
3helpful
DTC B1650 occupant classification system fault. 2007 DTC B1650 occupant classification system and the vehicle has been in a rear end collision and i tried to have the OCS reset but in vain, please help
If it is like a Chrysler, you will need to go to the dealer and have them redo the OCS. This has to do with the passenger airbag system and how much force it will send the air bag with.
12helpful
2answers
If the vehicle has been in a rear end collision, expect this. If not, it just may need to have the Occ Class Sys reset. Toyota Dealer only.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
