Question about Dishwashers
She47c0 bosch dishwasher won't stop the rinse cycle. the dry or sanitize signal does not iluminate. cleaned all arm nozzles,filter system. let it run with rinse agent and dishwasher salt. Need help! no clue! thanks!! Kat
  • Anonymous Sep 05, 2008
    mine won't exit wash cycle...after 2.5 hrs I finaly have to stop it
You're hosed.  This is likely a bad control board module that can run you in excess of $200.  Even if you're within Warranty, Bosch will gouge you for labor, as that is NOT covered by warranty.  Top that with abysmal customer service and you're in for a world of hurt.  Sorry, but it's time for a new dishwasher. :(
Posted on Oct 28, 2008
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
Bosch dishwasher stuck wash cycle
If you post your model number I and others may be able to help you further.
Short of that, it sounds like, the dishwasher stops because it's waiting for the water to get to the right temperature before it advances. If you open the door and the water is cold, you need to replace your heater because it's not heating the water. If the water is really hot, then replace the thermostat inside the door because it's not reading the water temperature correctly and advancing the timer.
Dec 16, 2013 | Dishwashers
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Rinse agent cycle
Visit Bosch web site and get a user manual. Or tray the authorized service center
May 02, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwaser is stuck in Rinse/Dry cycle
It could be a sensor or timer solenoid in the dishwasher maybe broken and needs replacing.
Apr 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher runs but does not clean
Try using a cycle that doesn't heat the water. (Quick cycle?) Using high heat rinse or sanitize will stop the timer while it heats the water. The sensor may be bad.
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
574 people viewed this question
Top Dishwashers Experts
