Question about Onkyo TX-DS575 Receiver
Yamaha RX-V660 right channel gone
I purchased a used Yamaha RX-V660 Receiver several years ago. Seems the right channel doesn't have sound. It's been on a stand, not used in a few years. Can it be repaired? Is it worth being repaired. Any feedback would be great.
Thanks
    Sergeant:
    Champion:
  • 248 Answers
Try checking the connections.
If your really value your receiver it would worth it.
Posted on Jun 22, 2008
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
Yamaha RX-V660 Receiver No lcd(?) display
Yes, this receiver is a good one. Alot of gear from a few years ago will still outperform new gear. And why change something if it can be repaired. It most probably has a blown backlamp to the lcd display...some models so easy to change that they just plug in!!. This is quite common and easily fixed. Heat kills electronics. If you wish to keep the old girl going i suggest trying to increase the ventilation. even by getting it into the coolest place in the cabinet. The top of the rack of gear is always best for your amp to get rid of the heat. and try to put some extra height(with say a 2 sticks of wood) under the feet both under the amp and any bits of gear that may sit on top while taking care to to block the ventilation holes. if the amp uses a rotary function selector switch it may have dirty contacts that are causing your crackling problems. A spray internally to the switches contacts with CRC 2-26 will sort that.
Jan 28, 2008 | Audio Players & Recorders
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Nov 09, 2009 | Audio Players & Recorders
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
May 21, 2009 | Yamaha RX-V596 Receiver
Yamaha RX-V870 receiver front right channel not working
There is a fuse in side the system you could try but that sounds like the channels is shorted, but yet again there could be a fuse for it
Nov 09, 2008 | Yamaha RX-V870 Receiver
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
Yamaha RX-V800 - No audio on left and right channels
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
Oct 30, 2007 | Yamaha RX-V2500 Receiver
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Onkyo TX-DS575 Receiver Logo
223 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
