Question about Sony Playstation 3 (PS3) Console
System update will not finish
I've tried about everything to get me system to update. The farthest i've got it was 35 percent before i got an error occurring (80710723) What do you think?
On mine it gets to 64% and then says there is an error (8002F1F9) and when i turn it off & on again it goes straight back to the update and keeps failing at 64%.
Posted on Nov 10, 2009
My doblo shows service overdue and oil change required, but its been done how can i turn thes off
Select the "Set" function in the diesel engine system.
  1. Start the function.
  2. Switch the ignition off and select "OK".
  3. Wait approx. 35 seconds for the reset to finish.
  4. When the reset has finished, switch on the ignition and select "OK".
  5. Check that the data list has been updated.
  6. The process is finished
Mar 03, 2017 | Fiat Doblo Cars & Trucks
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
From the description you have a hardware problem possibily caused by the ipod plugged into the headphone jack of the laptop. I'am convinced the sound section on the motherboard is damaged, probably the audio output ic. But to trouble shoot the problem will require someone with a strong background in electronics, I would suggest going no further until you have estimate in hand.
Jun 26, 2012 | Computers & Internet
Slow performance
First of all, SAVE ALL OF YOUR IMPORTANT DATA! Not programs, just Data. You can reload the programs.
Open Internet Explorer, Tools, Windows Update. Select Custom.
Install all the updates. Repeat until you no longer have updates to install.
Click Start, All Programs, Accessories, System Tools, Disk Cleanup.
While that is running open your TEMP folder and delete everything in it. Then open the Windows folder and delete all files starting with $NTUninstall. In the Windows\TEMP folder and delete everything.
After that I like to search for all *.bak; *.tmp and ~*.* files and delete them.(They're all temp files)
After all that Open My Computer and Right Click on the C: drive. On the Tools Tab select Check Now. Check Automatically Fix Errors and Scan For and Attemp Recovery of Bad Sectors. Click START and reboot your PC. This will take a long time. When that is finished, go back to Tools and Select Defragment Now. This also will take a long time.
This whole process takes a long time if this is the first time you've done it so, be patient.
Jun 06, 2012 | Toshiba Satellite U305-S2808 PC Notebook
My dell keeps giving me error codes when i try and connect a mouse to my system whats the problem
Try going to the device manager: start>control panel>hardware and sound>device manager. Look for mouse/pointing devices tab and expand to show HID compliant mouse, right click on it and choose update driver, then click search automatically for updated driver software.
Mar 13, 2012 | Dell Computers & Internet
335A-351F-2680-0F00-C000-0034
Your system was updating through a disk, if it has fialed then you must update manually with a USB Go to XBOX.com/support and look for the latest update
If your system is moddified then you must update your custome firmware and finish the update with the same disk.
Madden 12
Thanks
www.1RepairStop.com
We Fix Everything
Sep 03, 2011 | Microsoft Xbox 360 Console
What i do error 25090
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout regcleaner it will solve ur problem
Sep 01, 2010 | Microsoft Computers & Internet
Ps3 error 8002f14e
That is Failed Software Update, when that happens the system gets corrupted and cannot load anymore.
All you can do is downloading the update into an USB stick , plugging the memory stick into any of the USB ports on the PS3 and try to run the update again. Do it a couple of times.
If that does not work contact Sony, in some case they will replace the playstation becvause of this error.
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
Plz help...
A firmware update. Same happens to my friend's unit yp-u2(x) a 512 mb model.
In XP OS.
1. Download and install firmware updater.(manufacturer's support site)just key in model number and type.
2. Run updater, press and hold play button until its been detected fully by the updater.
3. Check the format box(My friend's unit firmware ver is 1.xxx to 2.xxx something when updated).
4. Hit the update button or something like that. do not detached the unit until its done. Unmount the unit using unmount method "Safely remove hardware".
5. Turn on the unit it should pass the 20 percent mark. When its good it has no file yet coz of format option. Just load your song.
I think it happens when too much file is upload in the unit. 60 percent of its capacity may be enough.
Hope it helps............
Jan 16, 2009 | Samsung YP-U2X Digital Media Player
A box come to install updates and when i push the install and it say installing updates but when it finishes it says some updates could be not be installed security updates for window XP then it shows...
One last thing :
turn off any ad-removal programs, Web accelerators, anti-spyware, and antivirus programs before you try to access the Microsoft Update site. These programs can cause script errors. Be sure to turn them back on once you’ve finished your update.
Mar 06, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
330 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
